In need of a chain learnin.
Discussion in 'Chainsaws and Power Equipment' started by Greenstick, Oct 29, 2018.
  1. Greenstick
    Greenstick
    Before I go in and stink things up, learn me. My only source of chain for 40 miles in any direction just got corporate stupidized if what I see is correct. Went to get a new chain and could only get Stihl or Trilink. Clueless at help desk said Trilink is replacing all other chains other than Stihl because it is a superior aftermarket chain. Looked in store and only way to run it right on my saw is complete bar change with chain. Clueless help said no you can run it without bar swap. I realize it is only around 10 thousands but my thinking is that the chain will run loose and wear the chain and bar faster by being sloppy all the time. 63 gauge chain must not be made by Trilink, only 50 gauge is what the store carried. Do they make 63 and need to get some ordered or if I get in a pinch am I forced into a whole bar swap? Might need to become a chain hoarder too:headbang:!
    Rope, Screwloose, Hammy and 6 others like this.
  2. OldJack
    OldJack
    Saskatchewan, Canada
    DBH, Screwloose, Hammy and 12 others like this.
  3. The Wood Wolverine
  4. Stlshrk
    Stlshrk
    Central Virginia
    Screwloose, Hammy, clemsonfor and 8 others like this.
  5. The Wood Wolverine
    I like Oregon LGX and Stihl RS. I have a new loop of the Oregon EXL but I haven't put it in wood yet. I'm not a fan of supporting the cheap chinese parts, chain included.
  6. TBONE
    TBONE
    Carey, Ohio
    If you can't wait for a chain to be sent to you I'd go with the Stihl, then order extras from any of the suggested sites.
  7. Brandon Scott
    Brandon Scott
    Formerly Rabbit Hash
    I use Stihl chains on my Huskies, they work very well. Not that this is of interest but I used to buy "Laser" chains out of Canada. Best chains I ever had. Haven't used them in years and not sure if they are still good quality.
    Screwloose, Hammy, Barcroftb and 4 others like this.
  8. Greenstick
    Greenstick
    Just to be sure on my thinking on the opening post. I could run the 50 on my 63 bar, correct? It would also wear on my bar and the chain in excess because of the slack, correct? Does Trilink even make a 63?
    Screwloose, Hammy, clemsonfor and 4 others like this.
  9. The Wood Wolverine
    You should run 63 on a 63 bar. You could run it, but your chain will wander in the cut, possibly bind and wear the bar quickly.
    And I don't support the shyknees when I don't have to, so no idea on the chi-link.
    DBH, Screwloose, Hammy and 10 others like this.
  10. huskihl
    huskihl
    Tri link is kinda the bottom of the barrel Chinese stuff. Never used it, but guys say it stretches bad and won't stay sharp.
    In my experience, with normal round filing or grinding, my preference from good to poor are:
    Stihl
    Carlton, Windsor, woodland pro
    Oregon
    Archer
    Brand x
    Brand y
    Brand z
    Forester branded chain
    Tri link
    10 other branded Chinese chains
  11. amateur cutter
    Don't run .050 0n .063. Wander & bar damage as stated above. As far as chain quality, this is the order I would most agree with. I'm not the worlds foremost expert on chain, but I've used/used up my fair share & I think huskihl hit it right on.
  12. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    I don't know what size you are running so here's the full search - not a suggestion on what chain to use just an option. I like having 3 chains.
    archerplus | eBay Stores
    10 - 14 per chain shipped depending on size and gauge. I think it is pretty good stuff. Archer did stretch a little bit initially but then OK. Have been using on a small saw 3/8 lopro full chisel that I square filed and have had no problems. I always factor in driving and fuel when I'm looking at something down the road. 40 miles round trip at say 20 mpg is 2 gallons = 6 bucks to me. So those 2 $20 chains down the road are 23 plus wear tear and time.
    Screwloose, Hammy, clemsonfor and 6 others like this.
  13. Greenstick
    Greenstick
    :rofl: :lol: perfect call! The CIA-NSA had your link all figured out for me! Very 1st set of chains are the ones the saw I am looking for needs! You are good:smoke:!
  14. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    It's just me. I think I would spring the extra 3 bucks for the full chisel chain on the next ad to the right. It will not stay sharp as long but will cut faster in clean wood. A 3/16 round file should fit both chains fine. It's gonna be hard to find a decent chain for $13.50 ish each shipped. Not a bad deal.
    Screwloose, Hammy, clemsonfor and 2 others like this.
  15. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    NEVER run a narrower driver than what the bar calls for !!!!!
    Screwloose, Hammy, clemsonfor and 3 others like this.
  16. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    The archer full chisel comes with a fairly aggressive grind. This is untouched 3/8 lopro.
    Screwloose, Hammy, clemsonfor and 5 others like this.
  17. lknchoppers
    lknchoppers
    Lincolnton, North Carolina
    Like the others said use a .063" chain in a .063" bar. If you have a vise and a 2 in 1 sharpener you won't need lots of chains, just keep sharpening the one you have until it's time to change. If I had to drive 40 miles to get a chain I would just mail order everything, it's cheap by the roll.
  18. Greenstick
    Greenstick
    There are a lot of things that are nice about living in the boondocks. Unfortunately convenience and shopping options are not some of them. Have made a couple calls and it looks like I have 1 chain choice and am at their mercy for amount they choose to stock by corporate overlords in another state. Or....drive 40 miles one way to locate chain. I realize it is the way of the world to do everything technology, mail order and corporate strings of store bulk buying to keep cost down but it sure has killed small rural business. Technology is great when it works but the slightest glitch can really send things into a tailspin if a guy lives and dies not being resourceful and inventive sometimes out in Dakotah Territory.
  19. OldJack
    OldJack
    It's the same up here in Rupert's Land. Actually I'm not too bad off for chainsaw stuff. It's 4 miles to Stihl, actually a store of billionaire Jimmy Pattison's mega John Deere dealership. 16 miles to Husqvarna and 40 miles to Dolmar, 2 stop signs going, 2 stop signs coming back. Echo is 60 miles away in the big city (Regina) with the last 5 miles all stop and go traffic lights. Never been there.
  20. Horkn
    I've actually used trilink chain as it is what was installed on my dolkita from home Depot. I would say that it stays as sharp as the Carlton that I get from Bailey's online. Also I have not noticed any stretch, none more than the Baileys or even the stihl RS chain I've run on my other saw.
    I had my cutting buddy sharpen the trilink after it dulled a bit, and it's sitting in my toolbox waiting to go on after this baileys gets dull. He also made it less of a safety chain, but exactly what he did, I'm not certain, and I have not cut with it after the sharpening.
    I don't like supporting China, but I've found that sometimes you can be surprised by the results.
