Almost time to fire them up for another season...
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Nomoredinojuice, Oct 16, 2018.
  1. Nomoredinojuice
    Nomoredinojuice
    Poughkeepsie NY
    With temps dropping and frost tomorrow night guess I am behind schedule. I Will have to clean stove this weekend and get ready for another season. Picked up some hamers for $265 @ rt82 agway. Let the season begin.
    ivanhoe, will711, slvrblkk and 4 others like this.
  2. BHags
    BHags
    Massachusetts
    First time trying Eco Woods Blend. $234/ton. We've been lighting the stove almost every night for a week now to get the chill out! Still cant get my glass as clean as I want, but I can live with it.
    ivanhoe, slvrblkk, Russell and 3 others like this.
  3. ttdberg
    ttdberg Pellet Pig
    CT
    Curious to hear how you make out with those Eco Woods. PD has been selling them for a few seasons now, but we never bought any. For the stove glass, have you tried the Rutland stove glass cleaner? It really works like a charm.
  4. Choo Choo Tommy
    Choo Choo Tommy
    Eastern Shore Md.
    My stove was running well last year, and I have use it for a few mornings this year. I have seen the dampness dry and it is easier to clean. Before the first burn the inside was damp and hard to scrape the walls of the stove. Hope this helps if your need a little burn before the full fall cleaning.
    ivanhoe, slvrblkk, Russell and 2 others like this.
  5. BHags
    BHags
    Massachusetts
    The eco woods look just like the easy blaze blend I had last year. Easy blaze btus is listed at 8250, eco listed as 8000, but eco is about $30/ton cheaper. I bought them at pellets direct. Time will tell.
    imacman, ivanhoe, slvrblkk and 2 others like this.
  6. Russell
    Russell
    South Coast , Massachusetts
    Mines been running on and off for about a month . Just did a quick exhaust chamber cleaning to see what things look like after a little burning .
    ivanhoe, CleanFire, slvrblkk and 2 others like this.
  7. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    is that normal??
    ivanhoe, slvrblkk and Russell like this.
  8. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    OMG!!!! its not.....is it???
  9. Russell
    Russell
    Yes the smoke and ash get drawn up and back down into that chamber so that's really not much for ash after a month of light burning.
  10. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  11. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    looked purty dirty......
    CleanFire, ivanhoe and slvrblkk like this.
  12. Russell
    Russell
    It depends on your stoves set up . I mean I'm pretty fuzzy I'm already checking and cleaning deep into the exhaust blower area :saw: but we'll see what our team of experts say :whistle:and don't forget it's running on low and with the Quadra Fire it's an on and off system so a fair amount of restarting cycles until it gets cold then it's running long and hot .
  13. slvrblkk
    slvrblkk
    Northampton, PA
    X2.....looks like a decent layer of ash lying in there? How many bags was that?
    ivanhoe, Russell, CleanFire and 3 others like this.
  14. kenstogie
    kenstogie
    Upstate NY Rentler County
    mine been on at nights for a week or so....
    will711, ivanhoe, imacman and 2 others like this.
  15. CleanFire
    CleanFire
    I say that's a really high quality picture you took Russell ! :D I can kinda make out the exhaust impeller in there.. Good to go until April ! :thumbs:
  16. Russell
    Russell
    Oh maybe 10 bags ?
    slvrblkk, ivanhoe and imacman like this.
  17. CleanFire
    CleanFire
    :eek:
    x3 - Did you block off the OAK or Exhaust venting @ end-of-season?
    FWIW, it is truly 'shoulder season' up here, have had to make several adjustments to tune combustion air over the past few weeks to keep the Francesca running well. This warm -> cold -> wet weather has had combustion air rate varying up to +/- 100 RPM .. As it gets colder -> outside air gets 'heavier', I'll be increasing the air rate more.
  18. MaineMtnMan
    MaineMtnMan
    I just cleaned the Harmon and did a test light. Smoke is coming out of the pipe at the first 90 behind the stove.
    Guess I gotta take the pipe apart and figure out what is going on
  19. Russell
    Russell
    I cover the outside exhaust vent with aluminum foil and put 2 containers of damp rid . I have to check the exhaust pipe again .
  20. imacman
    imacman
    Denver, NC
    A little stove ash, a paper towel, and a little water works just as well........and virtually free.:whistle:
