Tree Identification Help
Discussion in 'The Wood Pile' started by chemiee, Oct 20, 2018.
  1. chemiee
    chemiee
    NYC
    I have been wandering in nearby city forest 5 min walking distance to our house. It is filled with fallen dead trees, mostly oak.
    While looking for above the ground ( hanging) fallen oak tree, I saw a standing dead tree. I initially thought it is an oak tree but after cutting a few pieces I realized it is not oak.
    Cut pieces have distinctive smell. I can’t say it is bad. I kinda liked it. I am brand new to wood burning using a wood stove. Recently installed BK Ashford 25 insert and have been using it since last week and love it so far. Last year, we have used fireplace a few times . Other than that not much experience here. I only can tell if a firewood is oak or pine
    I can tell this tree seems hardwood though not so sure. It doesn’t smell like pine or cedar. And the pieces I cut and split already below %20 MC which is good because I do not have much space in our backyard to store green wood.I can only store what I can burn at the current year. I am posting the pictures of the cut and split piece. There is another, bigger standing dead tree next to the tree I cut. If I get a feedback that it is a tree with a good BTU , I can cut that tree too provided that it is also below %20.
    Thanks all in advance.[​IMG][​IMG][​IMG][​IMG]
  2. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    I’m guessing Swamp Ash!
  3. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Looks like some kind of ash. If the branching is opposite it's most likely ash.
    What I know as 'swamp ash' is Carolina Ash and it doesn't grow in your area. That being said I guess any ash that grows in or near a swamp is swamp ash. :cool:
    Leaves, branching, bark and buds are the best identifiers. Looks like you've only got branching and a bit of bark to identify the tree.
  4. chemiee
    chemiee
    NYC
    It is not in a swamp area.
    I’ll take another pic when I get there again and post it.
  5. Ctwoodtick
    Ctwoodtick
    Southeast ct
    I see ash too.
  6. HDRock
    It does look like ash , it sure is not softwood , it's below %20 Get all you can :saw::tree::axe::stacker:
  7. Backwoods Savage
    Wood looks like ash but not the kind of ash we have here.
    Welcome to the forum chemiee
  8. Suburban wood snob
    Suburban wood snob
    Milwaukee
    That's Ash. Tree just grew funny. Snap it up ash makes great firewood. Unless you have a postage stamp lot, there should be enough room for you to make small shelter (roof only) that should hold around 2 cords. Need more space efficiency??
    Build a holzhausen. Small footprint, tall, and zero cost.
  9. The Wood Wolverine
    I've cut plenty-o-ash and I can say I've never got excited about its smell. :whistle: Not that it's bad or anything.
  10. chemiee
    chemiee
    NYC
    I went to the site to take picture of the other tree next to the one I cut pieces but it was so dark and felt like early Halloween so I turned back before going deeper into the woods :)
    I’ll take more pics tomorrow. If it is ash, should split the small rounds? Or leave them as they are.[​IMG]
    Marvin, Thor, amateur cutter and 5 others like this.
  11. HDRock
    You can use your moisture meter to take a reading right After you have made a fresh cut on the end of A piece That will tell you if you need to split it or not
  12. chemiee
    chemiee
    NYC
    It is about 15% on the ends of rounds.So leaving them as round I guess will give longer burn time?
  13. Suburban wood snob
    Suburban wood snob
    Milwaukee
    15 seems a
    15 seems absurdly low for wood that was not split. The again ash starts out low...But 15 doesn't smell right
    amateur cutter likes this.
  14. jo191145
    They say temperature plays a role in measuring moisture. Maybe take a split indoors and let it warm up awhile and try again.
    Personally I’ve never tried such an experiment. Let us know if it changes your readings.
    T.Jeff Veal, Chaz, chemiee and 4 others like this.
  15. chemiee
    chemiee
    NYC
    I just took it again.
    Outside temperature is 62 so I think it should be fine.
    Marvin, T.Jeff Veal, Chaz and 5 others like this.
  16. jo191145
    Theoretically yes, longer slower burn. Tried and true wisdom in a non epa stove.
    Since I and my family moved up to hybrid stoves I’m getting the orders for smaller splits. I already was splitting them smaller to aid drying times but the womenfolk are asking for smaller yet. Stark contrast to years of past where “all nighters” were on the menu.
    In a cat stove the smaller splits will come up to temp faster allowing you to kick in the cat quicker. They won’t last as long but they seem to burn better with less chance of stalling the cat. And they last much longer than they would have in a non cat stove. My experience anyways.
    Anyone else like em smaller than years ago?
    LongShot, Chaz, TurboDiesel and 5 others like this.
  17. jo191145
    Excellent advice. If it’s dry burn it LOL
    Chaz, chemiee, amateur cutter and 3 others like this.
  18. HDRock
    To clarify testing moisture on the end ,You won't be able to just slice off an inch And then test it ,That won't l give you an accurate Reading of the inside of the wood .
    If you test it a couple of hours after you have cut it or split it It will not be accurate either
  19. chemiee
    chemiee
    NYC
    I just took it within an hour of cutting a long piece into a half.
    Chaz, amateur cutter and HDRock like this.
  20. HDRock
    Not really the norm but I have Split old 20 inch oak rounds that were 18%
    Looks like the stuff he's got there has been up off the ground too
    Chaz, amateur cutter and chemiee like this.
