Trouble getting straight cuts.
Discussion in 'Chainsaws and Power Equipment' started by T.Jeff Veal, Oct 6, 2018.
  1. jo191145
    Must assume this is the screw your referring to. Gotta admit I’ve never given it any thought. Must be a pain to dial in correctly but next time I’ll give it a try. Much will depend if the cheap grinders are actually contacting and maintaining the same diameter line of the blade I would imagine. That would be a miracle in itself :)
    Thanks for the heads up.
    Hammy, Marvin, Eric VW and 2 others like this.
  2. huskihl
    huskihl
    That's the correct adjustment. It works well. But if you go from .050 gauge to .058 or .063 it will require re-adjusting to be centered on that new width drive link. I'd imagine if it were set up for .058, it might be close enough for all 3
  3. stuckinthemuck
    stuckinthemuck
    Yeah. What huskihl said. Took me a while to learn what it does. Once the adjustment is done......easy as pie.
    Hammy, Marvin, Eric VW and 6 others like this.
  4. huskihl
    huskihl
    Mmm.
    Pie......
    Hammy, brenndatomu, Eric VW and 4 others like this.
  5. amateur cutter
    Hey, quit thinking about pie & go port my saws wouldya. :rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
    Hammy, brenndatomu, Eric VW and 5 others like this.
  6. billb3
    When my cuts look like that I call it operator error.
    Hammy, brenndatomu, Eric VW and 2 others like this.
  7. huskihl
    huskihl
    I'm getting there. Got too many torn apart needing parts to justify getting into another one or 2
    Hammy, brenndatomu, Eric VW and 3 others like this.
  8. bogydave
    If you aren't forcing the cut
    Worn bar is my guess.
  9. amateur cutter
    Just kidding, like l said, no hurry.
    Hammy, brenndatomu, huskihl and 2 others like this.
  10. saewoody
    saewoody
    Central CT
    After reading through the thread again, I believe I have discovered the problem. It’s a crooked log. . Should have left it in the woods; like choosing lumber at Home Depot, you need to go through at least 5 bad pieces before you find the right one.
    Bullet, Hammy, brenndatomu and 7 others like this.
