Pain in the Ash, Need Help
Discussion in 'The Wood Pile' started by bobdog2o02, Oct 4, 2018.
  1. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    The cost difference would only have been 300 for one less tank.... I prefer the peace of mind. Aside from that the volume that we have should last about 1 year between fills.
    Chaz, shack, Chvymn99 and 3 others like this.
  2. brenndatomu
    Ah, gotcha. I figured there was a reason they were there...just bustin your chops a bit. ;)
    I am surprised you can have them right next to the house like that...I think they have to be a certain distance from the house for the LP truck to fill them around here...
    More on topic...yeah the "suck factor" on that tree is rather high...
    Chaz, T.Jeff Veal, Chvymn99 and 2 others like this.
  3. Scotty Overkill
    That's gonna be quite a job, definitely going to need a bucket or lift. Ash limbs aren't safe to walk out on when they're that dead, heck it'd be risky to even rig pieces out.....
    Chaz, T.Jeff Veal, Chvymn99 and 5 others like this.
  4. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    But you think its doable in 1 day from a big lift?
    Eric VW, Chaz, T.Jeff Veal and 3 others like this.
  5. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Same rule here if they are over 110 gallons..... Sneaky way around the rule.... 4- 100 gallon tanks
    Loon, Eric VW, Chaz and 3 others like this.
  6. stuckinthemuck
    stuckinthemuck
    That gives you more surface area than 1-500 gallon tank. If I understand it correctly, more surface area is what you need to absorb heat from the surroundings allowing for propane evaporation to keep up with demand. Makes sense the way they did it.
  7. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Thats exactly right, need that surface area for when it gets cold......
    Eric VW, Chaz, stuckinthemuck and 4 others like this.
  8. Scotty Overkill
    It'd be a stretch, but should be doable.
    Eric VW, Chaz, bear 1998 and 3 others like this.
  9. Scotty Overkill
    A big bucket truck would be the way to go on that. If you can rent one for a day, Joe and I would operate it for ya.
    Eric VW, Chaz, bear 1998 and 4 others like this.
  10. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Define big, what should i ask for? I'll start calling around
  11. Scotty Overkill
    70 footer would be good for that job. If you get a JLG type lift, make sure it's an articulating lift.
    Brace yourself, it's gonna be pricey.
    Might pay you to get some quotes from local tree services, just to see where you're at.
    Chvymn99, Eric VW, bobdog2o02 and 2 others like this.
  12. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    "I know a few firends who work at the rental places nearby.
  13. Brandon Scott
    Brandon Scott
    Formerly Rabbit Hash
    I'm new here but I'm with some others. Hire a tree service. All they have to do is put it on the ground and then you can get high from the 2 stroke smoke... your life is worth a couple of bucks, even a grand...my $.02
    Loon, Stephiedoll, MikeInMa and 5 others like this.
  14. Brandon Scott
    Brandon Scott
    Can you get a large tank? I have a 1000 gallon tank. I have to pay extra rental per year but only like $50. Talk about peace of mind. I've had a couple winters here where propane would not have made it for 2 months. Good idea having the extra gasification surface area to cover your ash....
    bobdog2o02, Loon, Chaz and 2 others like this.
  15. Eric VW
    Video the whole d@mm day!!!!
    :D
    :thumbs:
    UncleJoe, Midwinter, Loon and 6 others like this.
  16. Brandon Scott
    Brandon Scott
    Ur a genius!
    Eric VW, Chaz, Chvymn99 and 1 other person like this.
  17. Scotty Overkill
    Ok, get some numbers and LMK.
    Chvymn99, Eric VW, bobdog2o02 and 3 others like this.
  18. Scotty Overkill
    So are you gonna be the cameraman?? Lol
    Please don't make his head swell up......
    He's actually our local "tree-nuis"...
  19. TurboDiesel
    Welcome to the club, Brandon Scott !:handshake:
    Another hoarder in Rabbit Hash?!?
    Who'da thought ?!?
  20. Chaz
    Chaz
    Southwestern NY
    :eek::jaw:
    What he said.. ^^^
    :whistle:
