Red oaks revenge
Discussion in 'The Wood Pile' started by TMACK, Oct 3, 2018.
  1. TMACK
    TMACK
    Minnesota
    Hauling home another load of red oak I got from a co-worker .
    Left me sit 20 miles from home changing it on the side of the road. Just glad I decided not to take the interstate. Need to figure out why it was rubbing inside wheel well.
  2. NH mountain man
    NH mountain man
    WMNF N.H.
    That's a tough day, at least you had a spare. There's nothing worse than a flat with a loaded truck or trailer, twice as hard to jack up.
  3. Backwoods Savage
  4. bear 1998
    bear 1998
    S.C.Pa
    Are your wheel bearings ok ? Maybe a broken leaf spring or more....
  5. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    Not flat but low with a load made it bulge more thus the rub??
  6. bear 1998
    bear 1998
    S.C.Pa
    This makes more sense than my thought!
    I would check it all if it were me..
  7. billb3
    How often do you check air pressure ?
  8. TMACK
    TMACK
    Minnesota
    The tires are fairly tight in the wheel wells and with big load on the bigger the bulge and then flexing going around the corner Even with 60#air
    Mechanical wise all is good. Going with smaller tires. 205 instead of 225. Should give plenty of room.
  9. ErikR
    ErikR
    Deep in the woods near Cable, WI
    I don't know anything about your trailer but please keep in mind that smaller tires may fit better in the wells, but they also have less load capacity! Check the sidewalls or the tire manufacturers web site for load info.... Also... any load bulge is at the bottom of the tire...
    Just saying, but like I said, I don't know anything about you trailer, number of axles, load capacity of the trailer, load capacity of your tires, age of your tires, or even if they're Chinese tires..... Some older Goodyear Marathons were made in China :(
  10. JB Sawman
    JB Sawman
    pennsylvania
    HEY,
    I have sold a lot of trailer tires a lot of trailers have limited clearance in the fenderwells sometimesI have had to try several brands of tires even though they are supposed to be the same size I have found as much as 1/2 inch difference in width you might have to do some shopping also a low tire would cause trailer to lean more and when turning would cause the fender to rub Good Luck JB
  11. TMACK
    TMACK
    Minnesota
    Tires always kept at 60-65psi.
    The fenders have inners that I took out today after work. That's what was rubbing. Got 1/4 to 3/8 inch clearance.
    Might look for wheel spacers. To gain another 1/4inch.
    Really want to keep these tires as they are like new and load range D .
