Chimney cleaning day!
Discussion in 'The Wood Pile' started by Warner, Sep 30, 2018.
  1. Warner
    Amongst other domestic projects I’ll be getting up on the roof and poking out the chimney today! I’m not a huge fan of climbing up the metal roof but it must be done. Waiting for the dew to burn off.
    Woodsnwoods, billb3, bang and 18 others like this.
  2. NYCountry
    NYCountry
    Mohegan Lake NY
    I gotta do it also some time this week . The temps are dropping quickly especially at night,
    billb3, J. Dirt, T.Jeff Veal and 8 others like this.
  3. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I need to do mine as well. Gott buy a ladder first. The one I have just barely reaches the gutters. Ok for cleaning, but not so much for mounting/dismounting
    billb3, J. Dirt, jo191145 and 8 others like this.
  4. Backwoods Savage
    We might give ours a check but don't expect to find much that needs cleaned. Been having fires in it already this season and no problems.
    billb3, J. Dirt, Pallet Pete and 6 others like this.
  5. brenndatomu
    Depending on your chimney design you might be able to clean bottom up with a Sooteater...
    billb3, J. Dirt, dingbat and 7 others like this.
  6. TMACK
    TMACK
    Minnesota
    Get em cleaned could be a polar vortex anytime now.:coldfire:
    I always try to get mine cleaned in the spring so it’s all ready in fall. Then just a quick inspection and lighter up.
    billb3, J. Dirt, dingbat and 9 others like this.
  7. Warner
    I have seen these, I have the old brush and fiberglass poles and can still get up on the roof, someday that may be the method I’ll adopt.
    We have a center masonary chimney with the clean out in the basement the soot eater will work great when I get an insulated liner and more efficient stove
    TurboDiesel, J. Dirt, dingbat and 7 others like this.
  8. bear 1998
    bear 1998
    S.C.Pa
    We just installed a metal roof....not steep...4/12 pitch. As long as the roof is dry ill continue to clean top down...its nice having no mess in the house. Just suck it out with ash vacuum when done....
    billb3, J. Dirt, dingbat and 6 others like this.
  9. jtstromsburg
    jtstromsburg
    Stromsburg, Nebraska
    Just cleaned mine Friday. The cap had chunks on it but the pipe only had 3/4c of ashy stuff. Last fall I had a grapes ice cream pail so much better. First Fire ended up happening Friday night as we’ve had several nights in low 40’s with daytime highs staying in low 50’a with rain. I’d rather than pay the gas man anyway.
    I’m behind on wood for this year so may either buy some or be more picky with only grabbing dead/dry stuff. Here’s to keeping the pipe clean another year
  10. MikeInMa
    Any processed wood block burners following this thread?
    If you burn those blocks exclusively, how often do you sweep your chimneys , and how much creosote do your find?
  11. Warner
    I got up there and poked it out. Surprisingly small amount of build up. Probably from burning dryier wood. I would have liked to take a pic from up there but I did not bring my phone with me and once down I’m not going back up till it needs to be done again.
    billb3, Chaz, J. Dirt and 7 others like this.
  12. jo191145
    Cleaned mine today. Might be my last time. 10 pitch roof is just getting to be too much. Used to dance on those things in my youth :)
    Been two seasons since I cleaned it. Got about 1/2 gallon of stuff out. More than most but I’m still not using covered wood. Non insulated flex pipe in a 18”x18” flue. Paid fifty bucks for it on CL. Some day I should upgrade.
    I’ll see Wednesday if I get the big score on EPDM rubber ;)
  13. J. Dirt
    J. Dirt
    Did mine Sunday! :salute: Full season of burning and hardly a handful of dust out of it.
    billb3, Chaz, Chvymn99 and 5 others like this.
  14. coreboy83
    coreboy83
    NW of Twin-Cities
    Did both of mine last weekend. Fireplace shelf was pretty full. Stove side had about 2 cups of fine powder
    billb3, Chaz, Maina and 5 others like this.
  15. SkidderDone
    SkidderDone
    Pollock Pines
    Must be contagious I did mine yesterday. Probably going to open the house up tonight and do a short fire for the first stinker burn. :fart:
    billb3, Chaz, Maina and 6 others like this.
  16. dingbat
    dingbat
    Western Northern Cackalaky
    Yup, did mine Sunday. Had to chuckle when I saw this thread.
    billb3, OldJack, Midwinter and 9 others like this.
  17. Woodwhore
    Woodwhore
    Mason NH
    Did mine today and i do it from the inside
    billb3, Chaz, dingbat and 7 others like this.
  18. J. Dirt
    J. Dirt
    One of those fiberglass rod reels?
    Firefighter, Chaz and bear 1998 like this.
  19. J. Dirt
    J. Dirt
    How much ladder you got there?:eek: Seems like a tall chimney?
    Firefighter, Chaz, dingbat and 2 others like this.
  20. Woodwhore
    Woodwhore
    Mason NH
    No i just connect the poles as i push up and out the chimney. Got the poles at lowes, they are very flexible. And i have the shopvac running in the hole as i do it so no dust comes in.
    Midwinter, Firefighter, Chaz and 3 others like this.
