Convection Fan
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by brokenwing, Nov 15, 2017.
  1. brokenwing
    brokenwing
    Northern MD, Near the PA LIne
    I hope everyone is doing well it’s been over a year, my health has had me really down and out! Since last winter the bearings in the convection motor like to squeal every once in a while, and then it will quiet down. I know it’s only a matter of time before it gives up. I want to order one and have it here for when the fan motor goes. The cheapest I can find is $300.00! Anyone know of any place else that is cheaper! Enviro M55, VF55 & Regency GC60 Convection Blower 80MM (50-2481)
    Last but not least you all love seeing a pellet stash, he is part of mine I just had delivered Monday!
  2. nailed_nailer
    nailed_nailer
    Cape Cod
    Quick search on Amazon for Enviro Part # 50-2481
    Shows one available at $229 (Prime so free shipping)
    Might be able to cross reference it to an industrial supplier like Grainger or McMaster Carr.
    I've never looked so Good Luck,
    ---Nailer---
  3. badbob
    badbob
    You ever oil it?Even if the rubber mounted bushing,at the non motor end,can sometimes be made to last quite a while,even if the hole is worn.
  4. ohbix
    ohbix
    OH
    Hi. Sorry to hear about your health challenges. 229 is the best price I've seen. fyi you can replace the bearings on the fan; I've done mine twice. If you include the end w/ the rubber seal, you will need 3 bearings - 2 for the motor, one for the opposite end. Might be worth changing bearings in the old fan and keeping it as a backup.
  5. brokenwing
    brokenwing
    Oh wow ty I never ever thought to check amazon for parts, that was greatly appreciated!
  6. brokenwing
    brokenwing
    To be honest I never attempted to oil it with the mindset of it being sealed bearings!
    bostonfan49, imacman, ivanhoe and 2 others like this.
  7. brokenwing
    brokenwing
    I will have to look at it, and see if that’s something I can do, would be nice to have a backup. Where do you buy your bearings?
  8. wildwest
  9. jtakeman
    Looks like the gangs about all here!! Welcome back......... brokenwing Sorry to hear your still having health issues. badbob Where ya been buddy!! Hope all is well?
    ohbix Welcome to the group!! Thanks for sharing. I too would be interested in what bearings are in the blowers.
  10. ivanhoe
    ivanhoe
    Northern Ontario
    Welcome ohbix:handshake:
    Nice of you sharing tips:yes:
  11. ohbix
    ohbix
    OH
    Bearings are 608 -2Z; I purchased SKF explorers for approx. $4 ea off of ebay. These are metal shielded; some folks have used the rubber shielded bearings in convection fans w/ no trouble. The first time I ordered thru NAPA, but they were very pricey!
    Hi everybody! I recognize names from another forum; wondered where everyone had gone...
  12. imacman
    imacman
    Denver, NC
    Welcome! :handshake:
  13. brokenwing
    brokenwing
    4F3D5D89-B48F-4E93-A4D7-87039680221F.jpeg C6D11984-E888-454F-B98E-F58D0CFDC0F2.jpeg 020570C2-3DE0-42FD-A7F1-0A566D34F173.jpeg 059E55A3-8C92-4BFA-9742-843A07672764.jpeg 9E7B4D4F-229E-497C-9447-9735C807C81B.jpeg Hey everyone, even though the blower was noisy I got it through this past winter. Today it was torn down, and found the bad bearing! Problem I do not have a small enough puller, so I’m going to check the local machine shops! The assembly is almost 300 dollars, so a bearing would be a heck of a lot cheaper! Anyone know where I could find this rubber bushing that the bearing sits in?
    bostonfan49, ivanhoe, imacman and 3 others like this.
  14. BHags
    BHags
    Massachusetts
    I've always had good luck for parts at "Pellet Stove Parts 4 Less". It's on line, never had a delivery issue.
  15. imacman
    imacman
    Denver, NC
    Don't think you'll find that part there. It might be a MFR. part only.
    bostonfan49, ivanhoe and brokenwing like this.
  16. Skier76
    Skier76
    CT and SoVT
    Keep us posted! My fan will occasionally make some noise on start up. I think I even started a thread about it awhile back.
    I appreciate you posting the pictures. Gives a good idea of what things look like when the fan is removed from the stove.
  17. brokenwing
    brokenwing
    Ok last update, took the blower assembly to the machine shop, the bearing was shot. Had the bearing replaced, fired up the stove same darn noise. It has to be something in the motor itself. It is intermittent, and primarily does it on a cold start. When it does act up it sounds like the squeal you get from the wear indicators on brake pads, stove has been up and running, and I will just replace it when it finally dies. Ty all for your help!
    bostonfan49, imacman and ivanhoe like this.
  18. badbob
    badbob
    You only replaced the bearing on the end of the wheel?The motor looks like a Ebm Papst,which also has replaceable bearings.
  19. brokenwing
    brokenwing
    I had the motor separated from the squirrel cage, but I did not see a bearing in that end. I only replaced the bearing opposite the motor. Strong possibility that I missed something. Hmm now I am wondering!
  20. badbob
    badbob
    There was also some of those stoves that made noise on startup,and was blower wheel hitting a piece of sheet metal.
