Back rack recommendations?
Discussion in 'Chainsaws and Power Equipment' started by Ohio, Sep 19, 2018.
  1. Ohio
    Not Ohio
    I have a 2010 2500 dodge ram. I figure it is only a matter of time before the back window takes an impact from a tossed split. Anyone have a back rack or headache rack that has held up well ie. Not rusted and does not obscure the rear view and easy to install. Thanks!
  2. RCBS
    Have you looked on CL yet? Most of the headache racks that I see are home-made/fabricated. Oilfield trucks. I would think it'd be easy to find one for a full size Dodge.
    Dunno if this would fit your truck, but there are others listed as well. Search term: Headache Rack
    Truck bed rack with headache
    Another:
    Ranch hand headache rack for pickup
    I have buddies who have had them on trucks, but again all were fabbed, not store bought...and they would probably be the only thing left of the truck in a catastrophic wreck. Many choose to create a 'box' pattern, running down the tops and sides of bedrails to hook into the rear supports that run up both sides inside the tailgate. 2x2 square stock is the preferred material for the racks themselves.
    Look/ask around...I bet you can get a good deal on a used one. Most oilfield trucks don't seem to survive much past 7-8 years.
    Chaz and Eric VW like this.
  3. Eric VW
  4. chris
    Best to make your own if possible need to have the open areas pretty small or use expanded metal panels with adequate support so a corner of a split can't reach the glass - I have busted out one yet- been some close calls though. I did crack the center panel on one truck ( corner of a split made it past) -haven't attemped to find a replacement yet. I do not need the whole window ($$$) .
    eatonpcat, Eric VW and RCBS like this.
  5. lknchoppers
    lknchoppers
    Lincolnton, North Carolina
    I always make my own from expanded steel. Grind it downs a little and paint it black. I build pressure treated wooden side racks too to double the bed capacity of the truck. Something like this, I'll see if I can find a picture of the headache rack section. Pressure treated wood for stake pockets you can get free at Lowes, the pressure treated lumber comes on it and they throw them away. They work great for making the stake pocket stakes.
    MaineMtnMan, eatonpcat, Chaz and 3 others like this.
  6. jetjr
    jetjr
    Pa/Md line
    I bought a new truck and need to figure something out as well.
    eatonpcat, Chaz and Eric VW like this.
  7. mike bayerl
    mike bayerl
    I have a Backrack brand on my Silverado. It is really well-made and not terribly expensive.
    RCBS, eatonpcat, Ohio and 2 others like this.
  8. Ohio
    Not Ohio
    I was looking at back rack brand and because they are inexpensive I was hesitant. That is good to know.
    RCBS and eatonpcat like this.
