Kubotas at play. Er, I mean work!
Discussion in 'Chainsaws and Power Equipment' started by Warner, Jan 20, 2018.
  1. Chazsbetterhalf
    Chazsbetterhalf
    Landscaping not to much. But already giving him a list. Even before it got here. Lol
  2. Well Seasoned
    Is the parking brake a hand lever that can be engaged while pressing the brake pedal?
    Maina and Chaz like this.
  3. Well Seasoned
    I know that Canadian border VT's sil is a mechanic- I believe worked on botas for quite some time.
  4. Chaz
    Chaz
    Southwestern NY
    No, it's foot activated, which is good I guess because I have to literally stand on it.
    :picard:
    chipper1, Maina and Well Seasoned like this.
  5. Chaz
    Chaz
    Southwestern NY
    Pic
  6. Well Seasoned
    Different setup than mine, ill need to look to see how mine engages and report back.
    Really important safety component, hopefully we can get it worked out. As an extra precaution when applicable, I keep the bucket down for added safety. The parking brake is weak even on the slightest hill. I can imagine if an unknowing operator was switching the front implements, there could be a danger of the tractor rolling on them.
    chipper1, Maina, mike bayerl and 2 others like this.
  7. Well Seasoned
    Not engaged.....
    Engaged......
    chipper1, Maina and Chaz like this.
  8. Chaz
    Chaz
    Southwestern NY
    Yeah, I'll definitely be getting this fixed ASAP
    Climbed on once, and accidentally stepped on reverse pedal, that coulda been a BAD day had I not made sure it was engaged prior to leaving the machine.
  9. Well Seasoned
    Watch for holes, these tractors can tip, and ill tell ya, it scared the chit outta me when it almost happened!
  10. eatonpcat
    Congrats on the new tractor Chaz, Looks like you got a great deal!
  11. 94BULLITT
    94BULLITT
    Frederick County, VA
    If your parking brake is that weak, your breaks probably need adjusted. On both of my Kubotas, the brakes were not adjusted right when new, but they had no problem holding the tractor. If you leave the brake on now and try to move you know it instantly.
  12. mike bayerl
    mike bayerl
    Been there, done that. Not cool. I think this is the reason that Kubota recommends getting on/off only on the left side.
  13. Chaz
    Chaz
    Southwestern NY
    Thx eatonpcat i was/am extremely stoked to get the deal we did on this tractor.
    Yeah, I drive it nice n slow. The center of gravity is a fair bit higher than I'm used to, or would prefer.
  14. Chaz
    Chaz
    Southwestern NY
    Thing is, I was.
    Just wasn't watching where I put my clod-hoppers.
    :picard:
  15. Born2Burn
    Born2Burn
    Youngstown, OH
    She loves it
    chipper1, Stlshrk, basod and 6 others like this.
  16. Canadian border VT
    I myself never trust Parking brake anyway, I always lower FEL just in case..
  17. mike bayerl
    mike bayerl
    Ugh! Last load of stones tonight and I managed to knock the front tire off the rim. These things happen when you run a CUT through wood with lots of boulders. I'll put the tire back soon enough. I hope it does not rain overnight. Lesson learned: Check the tire pressures every time you use your machine. I'm pretty sure this tire was low on pressure to start with and running it with a loader full of gravel through uneven woods was not the smartest decision I've ever made. TractorTireOff.jpg
    chipper1, Stlshrk, basod and 3 others like this.
  18. Canadian border VT
  19. Chaz
    Chaz
    Southwestern NY
    :doh:
    :hair:
  20. mike bayerl
    mike bayerl
    HAH!!!!!!!
