  1. Rich250
    Rich250
    Berks County PA.
    Drivers start your engines
    Finally :thumbs:
  2. gbreda
    gbreda
    NH
    Didnt think they would race today. Still light rain here and more predicted
  3. gbreda
    gbreda
    NH
    So, after replacing the saddle valve with a real ball valve, I am getting what I think is water hammer? When I shut off the water dispenser at the fridge or the fridge stops adding water for ice, it pluses the supply line (1/4" copper) making quite a noise.
    Current fridge is Whirlpool, previous fridge was LG and did not make any noise at all. I did not have the Whirlpool hooked up to water until I changed the valve so I dont know if the cause is from the fridge's valve design or the new valve supplying higher flow or pressure.
    The reducing tee and valve are on a 3/4" water line and adding an arrestor near the valve would be a royal beatch due to no room.
    Any thoughts here?
  4. imacman
    imacman
    Denver, NC
    My guess is that you now have a better flow/more pressure at the frig., and valve closing has to stop that..........hammer.
  5. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    you have a fridge that makes ice???
  6. gbreda
    gbreda
    NH
    Yeah, I caved on the last fridge and got one that makes ice cubes and did the same with the new Whirlpool. Sometimes I wish I didnt
    Although I do like having ice cubes all the time. Water, meh I get that from the faucet.
  7. gbreda
    gbreda
    NH
    Should have left the dam saddle valve in :picard:
    Does the arrestor need to be near the valve?
  8. gbreda
    gbreda
    NH
    and its purdy too :rofl: :lol:
    savemoney, wildwest, jtakeman and 5 others like this.
  9. imacman
    imacman
    Denver, NC
    AFAIK, it just has to be on the same supply pipe that you think has the problem.
  10. gbreda
    gbreda
    NH
  11. CleanFire
    CleanFire
    Have you tried partially closing the 3/4" valve, assuming it is the primary cutoff / only feed to the refrig. supply line ?
  12. Earl764
    Earl764
    CT
    I’ve found I have needed arrestors near sources of water hammer in my home. Especially with newer valves on things like a fridge or dishwasher.
    Maybe plumb it in where you have work space before the new valve?
    I do enjoy the ice feature on mine. Filtered ice+water.
  13. gbreda
    gbreda
    NH
    Yeah, tried that when I realized what the issue was. Didnt change anything which leads me to believe its pressure related and not flow related.
  14. gbreda
    gbreda
    NH
    Valve is in a tight area and was a motha to install
    Would the arrestor work better near the fridge? Its about 10 feet from the valve, which is in the basement
  15. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Happy birthday luneyburg
  16. gbreda
    gbreda
    NH
    X2 !!
  17. bogieb
    Happy birthday Luneyburg (first one to spell it correctly :D)
  18. imacman
    imacman
    Denver, NC
    X4 !
  19. IHATEPROPANE
    IHATEPROPANE
    X5!!!!!
    CleanFire, wildwest, imacman and 2 others like this.
  20. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Let me make X6!!!! or so.
