BX 2660 Fuel Tank Replacement
Discussion in 'Chainsaws and Power Equipment' started by Ralphie Boy, Jul 22, 2018.
  1. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    The plastic fuel tank on my bx 2660 has been in contact with some metal part on the mounting and now has a hole in rubbed in it. Anyone have a clue about how to remove the fuel tank?
    I'm sure all the body parts including the floorboards and fenders have to come off, but I've so far been able to find a takedown diagram or video on how to do it, so I've come to the experts at FHC for help.
    HELP!!:hair::hair:
    Screwloose, bear 1998 and Hammy like this.
  2. OhioStihl
    OhioStihl
    Southern Ohio
    I’m sorry you have to deal with that.
  3. Ralphie Boy
    Ralphie Boy
    I believe it's going quite the project. I may let Kubota do it....maybe....:makeitrain"
  4. brenndatomu
    Could it be repaired with something like this?
    Gas Tank Sealer
  5. Ralphie Boy
    Ralphie Boy
    It may, but it still has to come out. Probably some of the mounting hardware is loose or broken causing the tank to drop and rub. I haven't priced a tank yet, that bad news comes Monday.:picard:
    Screwloose, bear 1998, Hammy and 2 others like this.
  6. Bret Hart
    Bret Hart
    Central NY
    Might have that service manual. BRB.
  7. Bret Hart
    Bret Hart
    Central NY
    I have it. PM on the way.
    Screwloose, bear 1998, Hammy and 3 others like this.
  8. 94BULLITT
    94BULLITT
    Frederick County, VA
    Now would be a good time to change the fuel line also. The tank has to come loose to change it.
    Screwloose, Chaz, Hammy and 2 others like this.
  9. Ralphie Boy
    Ralphie Boy
    My thanks to member Bret Hart for getting me an electronic copy of the BX 2660 shop manual. It's going to make my life a good bit easier and save me about $300 in labor on this repair alone
    Brets actions once again prove what great folks are in the FHC family. You can always count on someone you've never met to help, no questions ask, when help is needed. Thanks again Bret!
    :salute::salute::salute::salute::salute:
  10. Chaz
    Chaz
    Southwestern NY
    Yep, there are some fine people that are here. :thumbs:
  11. Bret Hart
    Bret Hart
    Central NY
    No problem. Happy to help.
  12. Ralphie Boy
    Ralphie Boy
    The new fuel tank is in and the BX runs fine. Apparently one of the rubber grommets that holds the fuel tank securely in place fell out. The new tank is rock solid. I added extra protection by installing pieces of bicycle tire to cover anything that looked like is could contact the tank should it come loose again in the future.
    The job was made a lot easier because of the Kubota Shop Manual FHC member Bret Hart sent me. Not having to guess what steps to take and what order to take them sure made it easy.
    Thanks Bret!:salute:
    Just another reason I love this place!:thumbs::thumbs:
    Bret Hart, Stephiedoll, Chaz and 3 others like this.
  13. Hammy
    Hammy
    New Brunswick
    Ralphie Boy, brenndatomu and Chaz like this.
