Wood slabs hauling
Discussion in 'The Wood Pile' started by Heat550, Jul 16, 2018.
  1. Heat550
    Heat550
    Minnesota
    I was wondering has anyone came up with a good trailer or away to make trailer to haul them at 2000 lbs a piece bundles . Like to get up to 5 bundle a load . My last thought was a shorter trailer with 3 axels and 4 tall poles to stack between the and ratchet straps them down . Maybe even a distribution hitch. As weight piles on fast. Don't need to go fast just get job done .
    Any info or pictures to get project started.
    Sent from my LG-H900 using Tapatalk
  2. Born2Burn
    Born2Burn
    Youngstown, OH
    Friend of mine hauls up to 5 bundles at a time but he's using either a dual axle dump truck (loaded with slab) with a heavy duty equipment trailer (also loaded) or sometimes he will load his lowboy semi trailer.
    Having a pickup truck to haul 10k isn't unheard of I guess, but I would think you'd need one heck of a long gooseneck trailer to haul 5 at a time
  3. Heat550
    Heat550
    Minnesota
    I'm thinking on lines of stacking them over the axels but using like huge upright poles or like huge steel U so your stacking them up inside front and back. Semi trailer gives you idea about up rights . Other drawing is if I used a dump box trailer . I'm trying to concentrate the weight in smaller area .
    It's going to be heavy .
    Heat550
    It's like smv sign on the back and hit secondary roads.
    Here's a crazy thought hook to the motorhome it weight 12300 lbs 454 TBI with 4:88 rearend . Then towing rig is heavyer then the trailer [​IMG][​IMG]
  4. Heat550
    Heat550
    Minnesota
    Why isn't pics showing up ?
  5. MikeInMa
    I see the pictures
  6. Heat550
    Heat550
    Minnesota
    Ok it just might not be showing on my end .
  7. MikeInMa
    I've found that there are issues with tapatalk. Use a browser and you should see them. ☺
