The Boring Thread
Discussion in 'Hobbies and Interests' started by Garry Polmateer, Jul 4, 2018.
  1. Garry Polmateer
    Garry Polmateer
    Alplaus, NY
    Took a timber framing class earlier this year. I HAD TO get a boring machine.
    Found this Ajax on the bay for a fair price and got it rumning! Learning a ton and trying to stick with the “no power tools” mantra for woodworking projects where possible.
  2. Chaz
    Chaz
    Southwestern NY
    cool piece of equipment there. :yes:
  3. Garry Polmateer
    Garry Polmateer
    Alplaus, NY
    Test 001 was mostly a success. 2” holes in white pine. Need to sharpen the bit!
  4. Chaz
    Chaz
    Southwestern NY
    I see you got one that can do angle boring as well.
    A quick google showed quite a variety of pricing on those, none especially cheap, especially if it is adjustable.
    A nice find indeed, I hope (expect) that you will get many years worth of use and enjoyment out of that. :thumbs:
  5. Garry Polmateer
    Garry Polmateer
    Alplaus, NY
    Was like 240 shipped, not much more than a nice drill capable of turning a 2” auger, or at least that’s what I tell myself.
  6. M2theB
    M2theB
    Central Massachusetts
    Some of like our timber frames. Nice trade to know.
    metalcuttr, Shawn Curry, Chaz and 3 others like this.
  7. papadave
    Here's a vid from Wranglerstar about the one he found. I had never seen nor heard of such a tool until I saw his other vid about this one.
    Shawn Curry, Chaz, Eric VW and 3 others like this.
  8. papadave
    Here's his original vid.............lots of others on the Tube.
    Chaz, Eric VW and stihl sawing like this.
  9. Scotty Overkill
    Very cool! Imagine the old pioneers doing all that framing with merely a brace and bit!
  10. Scotty Overkill
    Then there was the mountain man, who used either a bow drill or a pump drill to burn the holes in......
  11. stihl sawing
    stihl sawing
    Arkansas
    That's a neat old drill. Never seen one. thanks for the pic.
    Chaz and Eric VW like this.
  12. Garry Polmateer
    Garry Polmateer
    Alplaus, NY
    Funny I saw the wranglerstar bids a while back and forgot aboutthem! Mine is a different variant than his. I was told there are only 8 or so different machines, the Ajax is middle of the road as far as age/sophostication.
    Mine is in ok shape, I need to replace a spring for the return mexhanism and find some period orrect looking hardwarw. Someone added hex bolts in a few spots. But it drills!
  13. Eric VW
    That’s pretty sweet right there Garry Polmateer :yes:
    No power cord saves you from paying the man, just like heating with wood.....they go hand in hand:handshake:
    Glennn, metalcuttr and Chaz like this.
  14. Garry Polmateer
    Garry Polmateer
    Alplaus, NY
    I don’t know if I will be building structures, have been using timber framing joints in furniture projects though! This is a wedged half dovetail that holds the bed rails in. I cut all of these with a chisel and took hours. Drilling will save 80% of the edfort I bet. Building bed #2 now!
    papadave, M2theB, Chaz and 2 others like this.
  15. Eric VW
    Ooooohhhhh Mr Curry......
    Shawn Curry :yes:
    Chaz and Shawn Curry like this.
  16. Shawn Curry
    Shawn Curry
    Western NY
    Nice find Garry! :yes: I’m a huge fan of the old-school tools myself, though I use a mix of hand and power. Is that a split-top bench that it’s sitting on?
    Drilling the mortises does save tons of work compared to chopping them. The technique I like to use is to chop the shoulders to 1/16” -> 1/8” deep on both sides; drill halfway thru from each side, and then finish up with the chisels. The shoulder helps to locate the hole quickly and precisely and guides the chopping afterwards.
  17. Garry Polmateer
    Garry Polmateer
    Alplaus, NY
    Yes I built the Paul Sellers bench but double and hsed 2x6 instead of 2x4. No frills wood, got two vises on ebay for a song. Going to add another dogging setup to the back side, I use it a ton. Love the tool well, wasn’t sure of I would like it. Now I have a place for everything, and everything in its place so to speak.
    papadave, Chaz, Eric VW and 1 other person like this.
