  1. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Arrg!
    Eric VW and imacman like this.
  2. gbreda
    gbreda
    NH
  3. Eric VW
    X infinity..... and beyond!!!:thumbs:
    imacman, gbreda, bogieb and 2 others like this.
  4. savemoney
    X8, I think, but I always lose count.
  5. bogieb
    I got one off of CL - since I'll only use a couple weeks a year (unless global warming really hits us hard), I didn't see a reason to get new. If I had gotten new, I would have most likely gone with dual hoses, but going used, you gets what is available (and in the price range I was willing to pay - no I am not paying $500 for a used unit).
    Anyway, picked it up last night and had it installed in not time. Closed off the bedroom, bathroom and den and set it at 77*. Let it run for a couple hours where it brought the LR and kitchen temp down to 83* and a lot less humid. By then, it was 82* outside, so I shut off the unit, opened up all the doors and started up the window fans. This morning it was still 80* in the house, and humidity had shot up overnight so I went thru the same routine as I got ready for work. Was down to 79* and I set it to run another hour after I left. I should get home in time to turn it back on before the temp in the house really starts rising from the late afternoon sun.
    Oh, and pic
    Rich250, savemoney, imacman and 2 others like this.
  6. bogieb
    Funny, I just realized that the window fan is behind the A/C in the picture - the edge of the window block can be seen behind the unit on the right hand side. I relocated that to my bedroom (there is one in the other bedroom too plus a 3-part tower fan that I move around to the most advantageous spot).
  7. imacman
    imacman
    Denver, NC
    Why not set the timer to turn on the unit an hour or so before you plan to be home?
  8. bogieb
    Because I don't know how to set the timer yet - no manual (and I can't find onw online - grrr). I'm not even sure I actually set it to turn itself off after an hour - I'll find out when I get home. I may not need it tonight at all - I just don't know. I don't like A/C so am not going to be running it just because I have it.
    Rich250, IHATEPROPANE and savemoney like this.
  9. Pete Zahria
    Pete Zahria
    New Hampster
    Oh..... You're gonna need it...
    Dan
  10. Earl764
    Earl764
    CT
    AC was set to a balmy 68 last night.
  11. gbreda
    gbreda
    NH
    Truck was dropped off this morning to look at the ac as its not cooling right. It works and then it doesnt, but mostly doesnt. Hoping its juts a recharge and not the compressor as with all the drives to my dad's being 1.5-2 hours each way its needed in the summer.......
  12. bogieb
    Your definition of need, and mine probably differ quite a bit. Was in the car a little while ago, going to/from Chiropractor and didn't use the A/C. Sign said it was 92* then and I could see the humidity in the air - wasn't even tempted at stop lights.
  13. bogieb
    That is freezing to me and would have a sweatshirt on.
  14. bogieb
    Hope it is the cheapest, easiest fix!
  15. artc
    artc
    Rocky Hill, CT
    the cheapest ,easiest fix is the one that came with the truck.... 260 air conditioning. open 2 windows and drive 60MPH that's all we had years back!:D
  16. savemoney
    Drove my Kea Soul to Lewiston this AM. AC on because of the high heat and humidity. Ozone was said to be unsafe. Had to redirect the blowing ice cold air away from the steering wheel! That little car was like a refrigerator. Good thing was that I could breath good in the cool air. From what I understand, this heat will last into the weekend. Don't know after that.
  17. gbreda
    gbreda
    NH
    Just talked with the mechanic. Looks like a recharge is in order.....hopefully
    I remember those days all too well. The older I get, the more i am using ac. I still dont use it a lot. open windows work for me 90% of the time, cept when its humid like now.
  18. savemoney
  19. bogieb
    Only works when you aren't driving 30 mph roads and hitting stop lights all the time.
  20. imacman
    imacman
    Denver, NC
    What brand? Model #?
    Rich250, IHATEPROPANE and jtakeman like this.
