Huskee 22 ton splitter
Discussion in 'Chainsaws and Power Equipment' started by buckman84, Jul 2, 2018.
  1. buckman84
    buckman84
    North carolina
    Im in need of a log catcher that can mount up to my huskee splitter. This is a splitter that I got from my late brother that I've had to do a bit of work to get it back in action. Push come to serve I may just weld something up but any ideas would be great.
    Eric VW, Maina, Chvymn99 and 3 others like this.
  2. TurboDiesel
    TSC keeps them in stock locally. IIRC $49
    If it's an older style they may be able to order one. You could fab one up pretty quick and just weld it on. Make sure it curves up a little or it will hit the tire in the horizontal position!
    Eric VW, Maina, Chvymn99 and 4 others like this.
  3. Hammy
    Hammy
    New Brunswick
    If you can’t find the one for your splitter you may be able to drill new holes in one meant for another brand. Pallet Pete just got one for his Dirty Hand Tools:
    It arrived this morning!
  4. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I believe that the ones at TSC are direct bolt for your splitter. I don’t know the price on them but I’ve seen them on the shelf.
    Eric VW, Hammy, Maina and 2 others like this.
  5. TurboDiesel
    Mine were direct bolt, but the top two attachments didn't last long (drilled and tapped holes in beam cradle). One bolt broke off the other fell out. The table was a little light weight for my style of splitting. Plan on just welding the table legs and adding a couple extra struts to reinforce the table.
    It's hard to see but I added the leg that is welded to the lower beam flange
    Here is the original unmodded table
    the two bolts through the web of the beam are fine but the top two bolt holes were drilled and tapped and the table came with bolts that were about 3/8" long. I knew they wouldn't last long when I put them in...
    Eric VW, Hammy, Chvymn99 and 4 others like this.
  6. buckman84
    buckman84
    North carolina
    I was looking at those, but while researching seen that my model splitter must be an earlier model. Does not have the rounded edge on top of beam. Dont see why that should hold me back. Not that bad of a little splitter. My old man and brother ran alot of wood through it. My other splitter is a beast. That was my dad's homemade one. Re-vamped it a few tears back.
    Eric VW, Hammy, Maina and 1 other person like this.
  7. TurboDiesel
    Good!
    My neighbor has the older style. Before the "cradle" design. I used his a lot before I bought mine. I actually think I prefer the older flat beam style. (The cradle works just as good until you get down to the 6-8" splits, then the splits will get down between the cradles and when the wedge pushes forward, it will smash the pieces out under the rounded rail and the pieces will get jammed or kinda torn on the sides. I learned to hold those smaller pieces up off the cradle to prevent the jamming.)
    It appears this one is in stock at TSC (at least it let me add it to my cart). Should fit the older style.
  8. buckman84
    buckman84
    North carolina
    That's good to know, the newer splitters are very similar to the tsc brand county line beams with the cradle design.
    Eric VW, Hammy and Maina like this.
  9. buckman84
    buckman84
    North carolina
    Thats my plan pick up a log catcher/ table, then try to look into a 4way wedge.
    Eric VW and Hammy like this.
  10. TurboDiesel
    Speeco, Huskee and County Line are the same. All made by Speeco. Although I was wondering if the latest TSC models are made by Speeco cause they look completely different.
    Hammy and Eric VW like this.
  11. buckman84
    buckman84
    North carolina
    When I picked up my brother's little splitter noticed that the tank had been damaged at the pivot point. Finally got around to patching the tank up, and went through the motor and got it running.
    Hammy likes this.
  12. buckman84
    buckman84
    North carolina
    Hammy likes this.
  13. Tiewire
    Tiewire
    Missouri
    For my table I welded on some square tubing like a receiver hitch. Will come off easily that way when needed.
  14. Tiewire
    Tiewire
    Missouri
