460 Magnum (from the dump)
Discussion in 'Chainsaws and Power Equipment' started by fuelrod, Jun 19, 2018.
  1. fuelrod
    fuelrod
    Western Maine
    I felt like a seagull at the dump this afternoon. Guy pulled up and tossed 2 chainsaws, about 8-10 air nailers of different types along with belt sanders, routers & saws. I left with this 460 Mag Stihl, a small DeWalt laminate router and a Porter Cable orbital sander.
    Is this a decent saw when running properly? My only comparison is my trusty 044. DSCN9701.JPG DSCN9704.JPG DSCN9703.JPG
    HoneyFuzz, M2theB, Hammy and 19 others like this.
  2. cre73
    cre73
    Central Il
    Nope it is a piece of junk. I will PM you my address and give you $50 for your troubles. Oh and by the way YOU SUCK, you lucky dog.
    M2theB, Hammy, basod and 13 others like this.
  3. Canadian border VT
    Great saw!! Good for you fuelrod
  4. Eric VW
    Depending on its condition, I will limit the “¥ou $uck” rating pending the pulling of the muffler to check for scoring/straight gassed.... unless you already got it started...and have bucked a cord...then it will be full on “¥ou $uck!”:D
    :thumbs:
    Certified106, M2theB, Hammy and 11 others like this.
  5. amateur cutter
    Uh yeah, what He said^^^^^ :rofl: :lol: Nice find!
  6. brenndatomu
    Mmm...yup, one large order of "you suck" inbound! :thumbs:
    Can't imagine why someone would throw that out like that, should be worthy of a rebuild all day long...unless LodgedTree got hold of it with his dozer...then maybe not...:whistle:
    HoneyFuzz, Hammy, eatonpcat and 12 others like this.
  7. OhioStihl
    OhioStihl
    Southern Ohio
    You might want to buy a lottery ticket.
  8. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Good saw for sure. The AM has a few decent parts for this series. Avoid AM cylinders.
    The handle looks bent.. some AM handles are ok for average use but will bend with hard/pro use.
    I’d go through everything and assume the tank leaks. If the case and crank are good, build that sucker up. It’d have more power than your 044 but probably not noticeable until you’re pulling a longer bar.
    Hammy, Chaz, Backwoods Savage and 7 others like this.
  9. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Nice! Keep us updated when you get it running and cutting a couple cords. I really like my 460.
  10. Mag Craft
    The 046 is a good saw and worth rebuilding. The saw is 76.5 cm with a 52mm piston. I have a couple of MS 460's which are pretty much the same and both have after market parts in them.
    They run good and have not had any problems with them. Have fun with your new saw.
    Hammy, tamarack, Chaz and 8 others like this.
  11. Horkn
    Yeah, you deserve a big old "you suck!!!!"
    Nice score. Does it pull over?
    Hammy, Chaz, Camber and 5 others like this.
  12. Maina
    Maina
    Are you sure it was a guy lol? Sounds like something a disgruntled ex might do...
    Horkn, fuelrod, Hammy and 12 others like this.
  13. Camber
    Camber
    Montana
    I'll admit that when I go to the dump, the first thing I do is go through the metal bin. Find out where the forest service dumps, and you will thank me. Fraud, waste, and abuse central.
    That was an excellent find. That sucker is definitely worth breaking down. Good job!
    Horkn, Hammy, bear 1998 and 7 others like this.
  14. Eric VW
    Hey yooperdave ......:whistle:
    :faint:
    Horkn, TurboDiesel, Hammy and 5 others like this.
  15. Backwoods Savage
    Wow!!! Sounds like you should have gotten even more than the saw. Great score.
    Horkn, fuelrod, Hammy and 7 others like this.
  16. 460 magnum
    460 magnum
    il
    Have you had anytime to fool with The saw?
    Horkn, fuelrod, Hammy and 5 others like this.
  17. Camber
    Camber
    Montana
    I was so jealous, I went dumpster diving. Got me a 365. Chain is brand new. Bar is good, doesn't even need dressed. Pulled the muff.....good to go from that side. I believe someone inherited it. The dump nazi told me the kid that brought it in said no compression. We'll I haven't tested yet, but I did pull the decompression out. Now it has compression:rofl: :lol:. It may not be a 460, but I have a 365 already that I love.
    HoneyFuzz, Horkn, fuelrod and 16 others like this.
  18. brenndatomu
    "Hey Mel, throw another order of "you suck" on the grill!" :p :D ;)
    :thumbs: Good one Camber!
    Horkn, fuelrod, M2theB and 9 others like this.
  19. Scotty Overkill
    You guys get ALL the good deals!!
    I'll say this much......after meeting fuelrod at the NE GTG last week and seeing what a great guy he is, he's deserving of a find like that!
    I hope it works out where it is a runner with little work. If not, he can always donate it to me.. ;)
    Horkn, fuelrod, p61 western and 10 others like this.
  20. fuelrod
    fuelrod
    Western Maine
    I have not fooled with it at all, that saw will be a wintertime project. I don't know how I posted it as a 460, :loco: :crazy: it's a 046. I don't feature myself as a collector but now I have an 044,045 & this 046. I kinda feel guilty not picking up the old Husky that he put in that pile, it was similar in (physical) size but it looked a bit more "boxy" like a much older saw. I did "eye up" a few kit's at Bailey's including an 82.5cc big bore :eek:
    Horkn, Hammy, bear 1998 and 11 others like this.
