CS590 Timeberwolf...NO START ??
Discussion in 'Chainsaws and Power Equipment' started by Satchmo1960, Jun 15, 2018.
  1. Satchmo1960
    Satchmo1960
    Urbana,Ohio
    I bought one new a few months back. I came home and started it up to cut a couple logs to check it out. I put it up and yesterday put in new fuel and no start and same thing this morning. Whats up and any tricks of the trade ??
    RCBS, M2theB, bear 1998 and 1 other person like this.
  2. bocefus78
    bocefus78
    What motor is on this unit? If its a honda gx, check your oil. They have a low oil, no start safety switch on them.
    RCBS, M2theB, bear 1998 and 2 others like this.
  3. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    This is a chainsaw....
    PatrickNY, RCBS, M2theB and 7 others like this.
  4. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Full choke and prime the bulb, pull until it burps, push choke in and pull until it starts.....
    RCBS, M2theB, Camber and 4 others like this.
  5. bocefus78
    bocefus78
    Brainfart. Saw the model and for whatever reason I thought sawmill or splitter. Beers seem to be working for me obviously :)
    RCBS, Camber, bear 1998 and 7 others like this.
  6. mike bayerl
    mike bayerl
    Check for fuel, air and spark. If no spark check the ground wire. Plug and coil should be fine. That should get you started.
    RCBS, Camber and Eric VW like this.
  7. Eric VW
    It happens....:yes:
    RCBS and bear 1998 like this.
  8. Satchmo1960
    Satchmo1960
    Urbana,Ohio
    It was flooded and apparently left choked too long. Blew out the plug and finally got it fired up..Thx for responses....
    RCBS, huskihl, Camber and 5 others like this.
  9. Mag Craft
    When in doubt Satchmo always pull the plug and see if it is wet or dry. Always a good starting point.
    RCBS, huskihl, OldJack and 6 others like this.
  10. Satchmo1960
    Satchmo1960
    Urbana,Ohio
    Thx Mag and I surely will
