Workin a big oak
Discussion in 'The Wood Pile' started by Woodwhore, Jun 6, 2018.
  1. Chaz
    Chaz
    Southwestern NY
    Woodwhore in that last pic, it looks like the pin is behind the slider for the ball lock.
    You should put the yoke over the ball, slide the cart forward till the ball hitch is nestled on the U portion. Then slide the yoke back and put the pin through the aligned holes.
    Not sure if I'm making any sense here or not. It took me nearly forever to get Chazsbetterhalf to lock it as well.
    Horkn likes this.
  2. Chaz
    Chaz
    Southwestern NY
    Align the holes on the sliding portion with the holes in the tongue portion and insert pin through the aligned holes.
    Horkn likes this.
  3. Chaz
    Chaz
    Southwestern NY
    Heh, with all this talk of sliding pins and holes, it can't be long till Eric VW shows up.
  4. Woodwhore
    Woodwhore
    Mason NH
    Yup the pin is in the closest hole to the ball
    Horkn and Eric VW like this.
  5. Woodwhore
    Woodwhore
    Mason NH
    Bi
    i take that back, i need to check it after work today
  6. Pallet Pete
    Pallet Pete Moderator
    Ovid
    That’s a nice setup for moving wood! :thumbs:
    Horkn, Woodwhore and Eric VW like this.
  7. billb3
    If it is like the one I saw in Tractor Supply there's two holes, one for using the yoke on a typical lawn tractor with the pin in the forward hole and then the further back hole for on a ball. I recall thinking that might wear kinda quick compared to a ball, but there was no adapter to lose.
    Chaz, Woodwhore and Eric VW like this.
  8. Woodwhore
    Woodwhore
    Mason NH
    Thank you pallet pete, the whole setup is only a few months old and iv moved alot of wood already, so nice not using the wheel barrow anymore.
    Horkn and Chaz like this.
  9. RCBS
    How do you keep your quad so clean??? :thumbs:
  10. Woodwhore
    Woodwhore
    Mason NH
    Its brand new, havnt even gone through a tank of gas yet.
    RCBS, Horkn and Shawn Curry like this.
  11. Woodwhore
    Woodwhore
    Mason NH
    I have the pin in the rt spot, i havnt had the trailer and quad together since that day. Today ill see what i can do.
    Horkn likes this.
  12. FatBoy85
    FatBoy85
    Washington State
    Saves a lot on the back I’m sure!
