Kubota B2650
Discussion in 'Chainsaws and Power Equipment' started by Well Seasoned, Dec 23, 2017.
  1. Maina
    Maina
    Nice forks WS! I like your wood rack too! :thumbs:
    Hammy and Well Seasoned like this.
  2. RCBS
    Load the tires? Or are they already?
    Hammy, Maina and Well Seasoned like this.
  3. mike bayerl
    mike bayerl
    Loaded tires and ballast are critical for a B series tractor. Ballast especially will help keep the rear wheels on the ground and take some of the weight off of the front axle. Great excuse to pick up some heavy rear attachments, like a box grader, skidding winch, back hoe...
  4. Well Seasoned
    Yes, they are loaded. So much weight far out front, definitely need ballast.
    Agree- next implement will be a box blade. (At some point) :yes:
    Hammy and Maina like this.
  5. Well Seasoned
    I did the 50 hour service today. Visual inspection of different things, greased everything, changed the oil and filter, which was pretty straight forward- Kubota could've kept the radiator hose away from the filter instead of up against, making it a little trickier than I would've liked- plus their will likely be a rubbing issue down the road from vibration.
    HST & Trans fluid stayed, only filter change, which again- straight forward, they seem to share the same reservoir. I needed Dawn to hold a shopvac at the fill area in the back, leaving just a small gap for suction without sucking up fluid while i switched filters. This trick worked great, only losing what was in the filter!! basod & MaineMtnMan this trick is worth looking up on YouTube when you hit your 50hr service!
    Other than that, moved some wood from below up.
    Maina, Hammy, 94BULLITT and 2 others like this.
  6. cnice_37
    cnice_37
    You have no ballast and picking that up??
    Maina, Hammy and Well Seasoned like this.
  7. Well Seasoned
    Just loaded tires and concrete on the rear. Really light wood and it did ok..... I was real careful
  8. cnice_37
    cnice_37
    No police here, just impressed! Can't see the concrete, about how many #s?
  9. Well Seasoned
    Just 3 blocks on a middle buster. :picard:This is just poplar, light stuff. When i have the $ we'll pickup a box blade
    Maina and Hammy like this.
  10. Well Seasoned
    Oh, and my phat azz ha ha ha
  11. Canadian border VT
    That particular kubota has a loader style with more lift capacity. IIRC 1250#, which was a selling point.
  12. Well Seasoned
    Yea- this was a selling point. Slightly more compact since the property is tight in spots at the moment until we continue to open it up. I'll show you this weekend Canadian border VT what we've done so far. We cleared an entire hill 90% along with the field of trees and brush opening up the view. Loads more to do. Anything and everything this loader has been impressive!
    Maina, cnice_37 and Hammy like this.
  13. Well Seasoned
    Gonna start working on these chains Canadian border VT fuelrod. Got the angle grinder ready, hopefully it's smooth sailing- getting ready for the storm tonight & tomorrow. Above freezing so decent conditions to put these on. Will snap a picture when they're on! :thumbs:
    :tractor:
    Maina, fuelrod, Hammy and 2 others like this.
  14. Well Seasoned
    Jack Straw
    I mounted the chains, left no issue, right side mounted but human error. I angle grinded the leftover chain after tightening it down, but realized it needed to be a little tighter. Ok, tightened, double checked both sides except the extra links, moved foward,clang clang clang. WTH was that? Chit, the extra links on the inner side slightly tore up the inner fender- that I missed cutting off! Oh well, couple bends and missing paint.
    Ok, we're good, hopefully we get through without any issues. Thanks again you know who you are involved in this!
    From the rear
    Left side, close but clear
    Right side, minor bending :emb:
    They look great and really dig in!
    I'll get something other than a couple bungee for the sides at some point
    basod, Maina, Chvymn99 and 7 others like this.
  15. LodgedTree
    LodgedTree
    Awww man, that sucks. I know it is cosmetic, but still, on a new tractor that sucks! For what it is worth, I am sorry that happened. :-(
    Maina, Chaz, Hammy and 2 others like this.
  16. Canadian border VT
    Chains are gonna make you :D..
    All tractors need a dent or 2 for character!!
    Maina, Chvymn99, Chaz and 3 others like this.
  17. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    They look awesome!
    Maina, Chvymn99, Chaz and 4 others like this.
  18. Well Seasoned
    Thanks, not worried about it, only you guys & I know it's there! :D
    Exactly buddy!
    :thumbs:
  19. Canadian border VT
    Now is the sander for truck or kubota?? What did you find..
    Maina, Chaz, Hammy and 3 others like this.
  20. Well Seasoned
    I was just looking, won't pull the trigger this year, but who knows. It would be for the tractor. Thinking a fertilizer spreader type. Saw one with decent reviews at tsc.
