Very relieved this morning
Discussion in 'Everything Else (off topic)' started by blacktail, May 15, 2018.
  1. blacktail
    blacktail
    PNW
    My neighbor recently levelled a spot for a new shed near our property line. I was gone yesterday and he sent me a bunch of text messages about stuff from my septic system bubbling up where the dirt had been moved.
    My drain field is on that side of my house, but it's about 15-20ft north of the bubbly goo. And I barely used any water in my house in the previous 24hrs. It seemed unlikely, but my neighbor was sure it was from my septic, which made me pretty nervous.
    When I got home after dark, I walked over with a light and saw the puddle of frothy brown liquid. I imagined the worst, spent a bunch of time reading about drain fields, looked up local companies that could do an inspection, and had a terrible time sleeping.
    First thing this morning I was out there to look into it further. 30 seconds with a shovel exposed the culprit. Just below the surface there's a root bleeding water out. Looks like the tractor broke it. It's from one of the huge maples i had cut down in january. My stumps are oozing a ton of water right now and when I drilled holes in them last week for the stump killer, the holes were instantly peeing water.
    Problem solved. Total cost: $0.
  2. brenndatomu
    Ha, that's pretty crazy! Good solve BT :yes:
  3. Backwoods Savage
    For sure that has to be a big relief. Now will the neighbor believe you? I surely hope so.
  4. blacktail
    blacktail
    PNW
    I left the root exposed for the neighbor to see and sent him a text about it. Our schedules are opposite so I only see him a couple days a week. When I first texted him about the root he thought I was wrong but then I sent him pics.
    I also noticed a couple of smaller roots doing the same thing where the tractor cut into the bank a bit.
    The amount of water in the stumps is crazy. The stump killer says to drill 1" holes, ad granules, then fill holes with water. I drilled the holes and before I could add the granules, the holes were full of water from the stump.
  5. cnice_37
    cnice_37
    That's nuts there is so much water from a root to cause that. Sure is good news.
  6. Eric VW
    Whew, what a relief:yes:
    ....speaking of relief...:fart:
  7. billb3
    Well unfortunate this is not a story about a man named Jed, a poor mountaineer that barely kept his family fed.
  8. MikeyB
    MikeyB
    Long Island NY
    That's nuts, great story.
  9. yooperdave
    Glad it turned out the way it has.
    I'm thinking the neighbor was a bit skeptical when he got your message though....at first!
  10. yooperdave
  11. brenndatomu
  12. NH mountain man
    NH mountain man
    WMNF N.H.
    Speaking from experience, you'd have known it was septic when you smelled it. So no smell tells you it ain't.
  13. yooperdave
    Yup, been there. Definitely obvious. In my cases, it was just seeping a bit and the smell wasn't bad.
  14. blacktail
    blacktail
    PNW
    This stuff has a foul smell. Almost like sewage. I drilled extra holes in the sides of the stumps thinking it may help kill it sooner. They're leaking nasty smelling foam too.
  15. blacktail
    blacktail
    PNW
    Each stump has a few holes spewing like this and it stinks. 20180516_111621.jpeg 20180516_111642.jpeg
