Time for Upgrade?
Discussion in 'Chainsaws and Power Equipment' started by ReelFaster, May 10, 2018.
  1. ReelFaster
    ReelFaster
    S.Jersey
    So 2yrs ago we moved to a home that backed up to a really nice wooded lot and has a traditional fireplace. Since then I've been hooked on collecting and splitting firewood. Being a novice at the time (and still pretty much am) I bought a lower end Tanaka (Hitachi) 40cc 18" Chainsaw. It's been pretty good to me for the most part. However lately I've had to correct a fuel leak problem and a stuck throttle which was pretty dangerous. But am handy enough and took it apart and cleaned it out and re-corrected the fuel line and throttle issue resolved itself with a cleaning.
    LN I was going to town on a stump from a dead tree I felled a few days ago, probably little too big for my saw but I went at it pretty good (see pic). It was only about 15" at the top but at the base is was approx 20". I got about 3/4 of the way and the saw was just smoking literally and was so hot. Wasn't able to restart it. Felt like the starter rope was skipping couldn't grip to turn the engine over. Took apart and looks like it's worn a bit (see pic). So ever since been thinking of an upgrade and going with a Stihl or a Husqvarna. Thinking back the past 2yrs I have used this saw a lot to drop many many trees and ones I had pro's drop I chopped up myself.
    Now oddly enough this morning after letting it cool all night when I tried to start it, it still did skip but no where near as bad as LN and I did get it cranked over. So I was looking for recommendations, I am not a pro but use it enough but don't need a monster. Was looking at the farm boss 50cc but that looks like a monster maybe little too heavy too much for my needs. Thanks in advance!!
    Hammy, Pallet Pete, leoht and 2 others like this.
  2. Canadian border VT
    Big difference really between stihl and husky is the clutch style.
    Go to a GTG try both pick one you like best:yes:
  3. Backwoods Savage
    They both make good saws. Pick the dealer you like the best or is the closest.
    ON the Stihl, I used a Farm Boss 290 for many years and the only problem I had with it is that it is a bit heavy for the size of the saw. I was just given a new pro saw; a Stihl 261 and it is so much better of a saw plus it is the pro saw and that alone makes is lighter to handle and it cuts much faster too. Give it a look. But don't discount the husky saws either. Others on here like the Echo saws too.
  4. TurboDiesel
    If you like the size and weight of the 40cc class you'd probably love a Stihl 241 and for a few more bucks the 261 is an excellent saw for firewood cutting.
    Both are professional grade (built to last) and have a great power to weight ratio!
  5. ReelFaster
    ReelFaster
    S.Jersey
    I just looked up the price on those and I needed to change my shorts........:eek::eek:. You get what you pay for I truly get it! Trying to stick in the $300 - $400 range and that's stretching it my wife is gonna kill me, LMAO!!!!!!!!!!!
    M2theB, Hammy, Pallet Pete and 6 others like this.
  6. Redfin
    Redfin
    central Pa
    Keep your eye open in the classifieds for used.
    M2theB, Hammy, chipper1 and 4 others like this.
  7. TurboDiesel
    If you were to buy a fireplace insert and a saw you would save enough money in 1-2 yrs to recoup the money and more.
    And! Keep the house warmer!
    Most wives can understand the keep-it-warmer part...:handshake:
    Hammy, Ashwatcher, chipper1 and 8 others like this.
  8. TurboDiesel
    You have a Dolmar dealer near by?
    How about a Makita from HD.
    They will occasionally sell off their rentals in good shape
    Hammy, chipper1, huskihl and 3 others like this.
  9. ReelFaster
    ReelFaster
    S.Jersey
    Thanks Turbo, your 100% right it would. FP Insert is on agenda for this fall/winter, if I get that.......o hell am breaking the credit card out for a top of the line Stihl I will be able to justify it all day long and twice on Sunday :)
  10. Redfin
    Redfin
    central Pa
    I would look at the Dolmar 5105 if your set on new.
    Hammy, chipper1, huskihl and 8 others like this.
  11. ReelFaster
    ReelFaster
    S.Jersey
    Thats a nice looking saw John, light and powerful.....
  12. Jon_E
    Jon_E
    Southwestern Vermont
    For your budget, and size of saw, Echo CS-490 or Makita EA4300.
  13. mark.nowak
    mark.nowak
    Sycamore, IL
    Look at the Stihl MS 251, great saw for the money, probably perfect for your needs and fits your budget.
    Pro saws are great, I would love to have one but they don’t fit my budget either.
  14. Moparmyway
    Moparmyway
    New York
    One thing to consider is what happened to your saw. Flush cutting stumps puts the exhaust discharge in the corner of the stump and the dirt, leaving the heat nowhere to go except back into the saws intake and cooling air. The heat from the exhaust starts cooking the saw and can permanently damage it if you’re not carefull.
    That sounds like what happened with your saw.
    It’s best for the saw to keep a few inches between the ground and the exhaust discharge, giving the heat room to escape
    Also, root blooms typically have sand, rocks, and dirt embedded into the wood and bark. This is where semi-chisel shines. Full chisel will dull real fast, adding the additional saw killing ingredient of high rpm’s screaming without cutting ...........
    The stump can kill a saw faster than most realize, no matter what saw you choose
    Redfin, Khntr85, Chaz and 2 others like this.
  15. Duane(Pa)
    Duane(Pa)
    Centre Co.
    I would never pay CC interest on a chainsaw. Find something you can pay cash for (new or used). You may have to save a while, that is good. You will have more time to narrow down your needs and wants... DW
    Hammy, chipper1, huskihl and 4 others like this.
  16. TurboDiesel
    Then in comes Duane with the voice of reason...:hair:
    :whistle:
    Hammy, chipper1, huskihl and 2 others like this.
  17. Horkn
    They sure do. 64cc saws used in great shape for $300 is a great deal. They rent a smaller size too.
  18. ReelFaster
    ReelFaster
    S.Jersey
    How about a Dolmar 5105 says gently used, looks like in pretty good condition for $350? Seeing one in my area on Craigslist!!!! I prefer to go new and like the Stihl MS 251 but hearing some complaints as it's not a true 18" bar and single nut to hold the bar on.
    Hammy, Horkn, chipper1 and 1 other person like this.
  19. Jon_E
    Jon_E
    Dolmar 5105 for $350 is pretty decent. I'd buy it.
    Hammy, Horkn, chipper1 and 2 others like this.
  20. Barcroftb
    Barcroftb
    The Mitten
    No offense to anybody, but I see very little reason to recommend the stihl ms250 over an echo cs490, and I like Stihl saws as much as anyone. One is a pro quality saw the other is a homeowner saw.
    Beyond the saw issue you have been having, let's talk about the tree you cut down. It's hard to tell from the pic, but it looks like the face cut on that stump is dodgy.
    There are some parts of this video I don't necessarily agree with, but it's a good place for you to start.
    Hammy, Backwoods Savage and chipper1 like this.
