Bummer
Discussion in 'Chainsaws and Power Equipment' started by Stephiedoll, May 6, 2018.
  1. Stephiedoll
    Stephiedoll
    Omaha, NE.
    This, can't be good. Had the 32" bar with new chain on it. As far as I got on it today. Any ideas?
    Screwloose and M2theB like this.
  2. Dancan
    Dancan
    ns canada
    Well bummer is right , I can't "Like" them pics :(
    Looks like it got leaned out .
    Horkn, Mag Craft, Screwloose and 2 others like this.
  3. brenndatomu
    Yeah looks lean for sure, been sitting a while?
    Not straight gassed I assume?
    That the Stihl?
    Screwloose, Shawn Curry and M2theB like this.
  4. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Yep, 660. Gas was in it awhile, not sure how long, but I've never had a problem before and always run e-free premium about 40 to 1. Need to decide if I should get another big bore for it, not sure the brand on it now, or aftermarket. OEM is a little high for me. Not set up to pressure test it.
    Horkn, Mag Craft, Chaz and 2 others like this.
  5. brenndatomu
    There is some decent aftermarket stuff out there...I guess it just depends on what you want. Hopefully its just the top end and the crank/bearings are still OK. I'm not nearly the saw guru that some of the others on here are. I know Armbru84 usually has some 660 parts laying around...if he doesn't then I'm sure he would know where to point you...
    Horkn, Chaz, blacksmith and 4 others like this.
  6. Armbru84
    Armbru84
    Sparta, Michigan
    I have a decent amount still but only one piston and cylinder. I built a MMWS cross cylinder and put it on a 660 I built for amateur cutter and it runs really good. You have to pay attention to the bevels on the ports though and I know that can be a pain :binoculars:
    I can try to track you down a used oem cylinder if you want. Just let me know.
    Horkn, Moparmyway, Dancan and 5 others like this.
  7. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Not straight gassed. I guess I learned my lesson leaving gas in saws. I would guess it sat 6-8 months with the gas in it, maybe June last year. My bad, but have to move forward. Purchased the saw from a member on AS 6-7 years ago. I know it has a big bore kit with no base gasket and he said it tested at 200psi when he sent it, almost more than I can handle. I've looked at MWP big bore and Meteor kits (same price) and I think they have good reputations from members. I also think it was a MWP kit I put in my best friend's Husky 261 8 or so years ago and it still runs great.
    Any advice is appreciated and at least it's not the most expensive mistake I've ever made.:headbang:
    Horkn, Hammy, Chaz and 4 others like this.
  8. Shawn Curry
    Shawn Curry
    Western NY
    An air leak can cause lean condition as well. I’d get the pressure test kit and test that too before running too long with a new cylinder on there.
    Horkn, Dancan, Chaz and 3 others like this.
  9. Nixon
    Nixon
    West Sunbury,Pa .
    ^^^^^ this . Don’t put money and time into changing the P&C until you can determine the cause of the failure . You can pick up a mity-vac kit at very reasonable prices on ebay . You can use Gorilla tape for block off plates on the intake and exhaust .
    Horkn, RCBS, Chaz and 3 others like this.
  10. Armbru84
    Armbru84
    Sparta, Michigan
    huskihl may have some decent thoughts on AM kits. I don’t know a ton about Meteor but have heard good things.
    Horkn, Mag Craft, huskihl and 4 others like this.
  11. Redfin
    Redfin
    central Pa
    Id look at the screen in the carb also to make sure its not plugged.
    Horkn, Moparmyway and huskihl like this.
  12. huskihl
    huskihl
    The only AM kit I trust right now is the Cross MMWS kit, but it needs the center of the exhaust floor and roof beveled better or it'll hang a ring. The one you have may also clean up. But you need to find what caused it. Either an air leak, tune, or the gas separated from the oil while sitting. Or like John mentioned, the screen is plugged.
    If you'd like, and if you end up going with the Cross kit, you could have it sent to me and I'd bevel the ports better and ship it to you
    Just pay the added shipping
  13. Canadian border VT
    huskihl, great offer, great member:tip::tip:
    Horkn, amateur cutter, Chaz and 4 others like this.
  14. brenndatomu
    That's the one I will probably put on "Mu Shu 660" if the Chinees P/C craps the bed...
    Horkn, Chvymn99 and huskihl like this.
  15. huskihl
    huskihl
    The FT cylinder that came on them are a crapshoot, depending on which one you got. The plating doesn't like staying put. Also, I've seen at least 2 different cylinder kits sold as part of the kit. I have a couple. Definitely fun projects
  16. brenndatomu
    So far so good with mine...not a ton of time on it though. It looked pretty good other than the plating that was peeling inside the ports when I got it...I figured things weren't "prepped" for it to stay put in there anyways...so ground it out while cleaning the ports up a lil bit too. And it had the sharp edges on the ports that needed chamfered too.
    Put it together sans base gasket...low 20s on the squish...runs pretty good...put a 32" bar on, it pulls that well. But it felt like a dog after running Armbru84 s "juiced" 084 with a "short" bar on it though...:eek:
    Horkn, Chvymn99, Hammy and 1 other person like this.
  17. huskihl
    huskihl
    Plating in the ports flaking off.....mine had it too.
  18. brenndatomu
    I made the assumption that it was no big deal...seemed like it was kinda "overspray"
  19. huskihl
    huskihl
    I think you're exactly right
    Horkn, Chvymn99 and brenndatomu like this.
  20. Mag Craft
    Looks like it scored right across the rings. That is a shame.
    The Meteor pistons for the 066 Stihls I think are pretty good. I have one I installed in one of my saws and have been milling with it and so far it has held up real well.
    I would also try and save the cylinder. A lot of the time it is just aluminum transfer and can be removed.
    Horkn, brenndatomu and Moparmyway like this.
