Anyone ever half and quarter big oak rounds like this?
Discussion in 'The Wood Pile' started by mikeward, May 2, 2018.
  1. mikeward
    mikeward
    Long Island, New York
    We went from low 40s to 80s in a day. Had last fire couple of days ago.
    Have a bunch of big rounds to split and really don't like wrestling with them when they don't split cleanly in half. I tried rolling them on the foot of splitter and the weight of the half rounds really help them to come apart cleanly. Only had one round that I still had to wrestle with.
    I halved and quartered around 12 rounds and now will split normally. All red oak.
  2. clemsonfor
    Never done it. I usually noodle it. But if that works thats faster, more handeling but faster
    Sent from my SM-G900V using Tapatalk
  3. MikeInMa
    Oh sure - except manually sledgin' & wedgin' -
    A little noodle just to get the wedges in.
    A few taps and it'll split where it wants to
    Then just the x27 to deal with any strings
    tamarack, Ashwatcher, M2theB and 17 others like this.
  4. clemsonfor
  5. mikeward
    mikeward
    clemsonfor , MikeInMa I've done both ways in past but this was FAST. Just rolled onto foot and boom 2 halves. Then tilted and flipped half to make a quarter. These rounds have been sitting for a year so I stripped off bark the other day ( 2 green landscape barrels full). They rolled easy to splitter. Now to finish up and do more
  6. MikeInMa
    I halved and quartered them just to be able to move and stack them. I'll get to splitting them to stove size, over time.
  7. Backwoods Savage
    I've split many even larger than those but never used that position; always laid them flat but have have thought about trying it the way you've done it.
  8. billb3
    Yes, rather than make the effort to stand it up, just roll it over and attack it from the side. It works with some rounds.
    Red oak rounds are usually so easy to pop open with a wedge and heavy hammer of some sort that I often don't even make the effort of rolling them. But then again rolling them is sometimes easier or faster than carrying chunks. Depends too much on the situation for just one standard .
    Pine is so inconsistent from one round to the next I just stand them up.
    Never had much big maple.
  9. Will C
    Will C
    New York
    I have split large rounds when getting wood out of the woods with my RTV or any method where I was loading by hand. I always ask myself "is it more work to half or quarter or lift the round?" And proceed accordingly!
  10. EnglishBob
    EnglishBob
    Upstate NY
    I always noodle mine all they way through, roll them onto a couple of small tree limbs to get them off the ground.
  11. JPDavis
    JPDavis
    Prescott, AZ
    I've never tried it that way or even thought about it. When I get my splitter back from my neighbor I think I'll try your technique.
    Chaz, clemsonfor, FatBoy85 and 8 others like this.
  12. Eric VW
    I like it, but as mentioned above, probably best with straight grained wood....:yes:
    Chaz, clemsonfor, FatBoy85 and 6 others like this.
  13. Jon_E
    Jon_E
    Southwestern Vermont
    I have a 24” bar on my larger saw and I cut everything to 20” length, so I noodle anything I can’t lift. I will occasionally pull out a maul if the pieces have nice straight grain.
    Eric VW, Chaz, clemsonfor and 6 others like this.
  14. BigPapi
    BigPapi
    The hills of Western MA
    I tried it for the first time the other day when wrestling a good sized mess of a sugar maple crotch. Had to hand split and noodle it in half, then was able to wrestle the halves to the splitter. Twisty mess it was, should have just noodled them. Tried flipping them horizontal, which helped. Wound up with a pile of splits that looked like a bomb went off in the middle, and nearly filled a short bed pickup, tossed in.
  15. basod
    basod
    Mount Cheaha AL
    I thought about doing it on this stump cut the other day, wouldn't half or bust with multiple saw strikes
    Eric VW, Chaz, clemsonfor and 4 others like this.
  16. brenndatomu
    Yup, just did it on a big Ash round tonight...POP!
    Eric VW, Chaz, Thor and 7 others like this.
  17. Erik B
    Erik B
    Western Wisconsin
    Flip that round to the other side and see if that helps getting it to split.
  18. mikeward
    mikeward
    brenndatomu glad it worked for you too
    I don't do this too often but with strait grained wood that will roll onto foot of splitter, it's easier than splitting normally for me. The biggest round I can roll onto splitter would be 26 inches. That's with splitter wedge all the way up.
    What I like best is the weight of the round helps finish the split. The little stringy bits of oak left connected between the two halfs break quickly as the round opens up and falls to the ground.
    Once it's in half I flip it on the flat and split it normally but with the flat against the beam of splitter.
    Everyone has little tricks they learn when using a splitter to split wood this is just one to be used when appropriate.
    Actually that would probably be a good thread to start , "Tricks and tips to use when splitting wood"
    In my splitting area I've only had to noodle a few times. I've used wedges many times and with oak it is quick on the really big rounds.
    Gotta say that this splitter has been great. It's a 22 ton with a honda engine and there was only one round that it would not split. It was a big oak round that had 4 big branches coming out. Talk about confused grain pattern. Stopped the wedge no matter how I positioned it. Had to noodle it in half. That eased up grain pressure and it split fine.
    Eric VW, Maina, Chaz and 3 others like this.
  19. NH mountain man
    NH mountain man
    WMNF N.H.
    I never tried it that way, but will with the right wood.
  20. FatBoy85
    FatBoy85
    Washington State
    Yeah I’ve tried this with pretty large and wet rounds. Weight wise was the main reason to split them into manageable pieces to carry and let dry before splitting again. It is definitely worth splitting a round into quarters or thirds to let a majority of it dry out for a little while. At least the 2-3 year plan will help any new wood coming in to be ready for any additional processing in time if they are just so bulky to begin with.
    NH mountain man, Maina, Chaz and 4 others like this.
