Does anyone here just have a masonry fireplace?
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by B_Williams, Feb 21, 2014.
  1. B_Williams
    B_Williams
    Maryland
    Hi all,
    I've lurked for a while but finally joined. I also watch FHC on the Roku:thumbs:. In 2012 my wife and I bought our first house, a nice little rancher with a fireplace. It's older but has charm, including the original wood burning fireplace. I have access to quite a bit of free wood at work (I just have to process) and we like burning even though we know the fireplace is inefficient. It helps that we have a NG furnace.
    Is there anyone else on these boards only using a masonry fireplace? We REALLY enjoy it and I also like processing wood. We're in the process of finishing the basement (previously gutted due to flooding) and the previous owners left a wood stove when they moved, so we'll probably hook that up once the basement is complete. But until then, it's the fireplace. Anyone else in a similar situation?
    -- B
  2. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Welcome B.
    We burned for a few seasons in our masonry fireplace. We enjoyed having that open fire in the living room. (especially the night we lit a pile of lath from a wall demolition upo_O) After a bit of online reading, we realized the inefficency of it and started looking for a stove.
    To me this whole woodburning journey is a learning process. We are now on our third stove(thanks to CL), each one more suited to what we need. As I look back, I am glad we made the change. I won't make this a bashing response on fireplaces, but switching to a stove or insert far outweighs the ambience of a fire IMO. When you think about a draft going up a fireplace, it is your warm, heated air leaving the house at an accelerated pace.
    Very good friends of ours use their fireplace frequently. They have an older house, so you are really warm facing the fireplace, but the draft pulled in from around the windows and other rooms is not pleasant. It is nice to sit around and watch the fire crackle away, I miss that just a little. Keeping more heat in the house and letting it heat the objects in the room is a plus. Cooking on the stove top is a bonus on those long cold winter days.
    Scotty Overkill and Stinny like this.
  3. B_Williams
    B_Williams
    Maryland
    I know what you mean. If you look closely you can see dust particles heading straight for the fire...
    I just can't get over how much inserts cost. It'd take about ten years for us to break even based on what we spend heating with NG. That said, I think it's in our future and I'm pretty excited to get the basement stove hooked up again.
  4. firecracker_77
    firecracker_77
    IL
    Any stove can be converted to a fireplace. Simply open the front door of the stove and burn it open. I like the heat of a woodstove more than the crackle, but you can open that door and have both.
  5. My IS heats my home
    My IS heats my home
    Albany, NH
    I have to agree. If you are serious enough about wanting to heat with wood you will find a way to heat in your masonry fireplace.
    OR you could stick with the aesthetics and heat in your basement and hope that will heat most of the upstairs.
  6. firecracker_77
    firecracker_77
    IL
  7. B_Williams
    B_Williams
    Maryland
    Yeah. We're working on the basement and there's a stove already down there. We'll use that for now even though I'm not so sure it's a good one. It's a Country Flame 3825 and from what I can tell, from the 1980s.
    I'm pretty sure after a season or two, the wife's gonna be all over wood heat and we'll get an insert for the living room. That's how it plays out in my head at least. We'll see how it goes down. She certainly likes sitting by the fireplace when it's going.
    firecracker_77 likes this.
  8. firecracker_77
    firecracker_77
    IL
    That sounds good. Some people have fireplaces and don't use them. That is always unimaginable to me.
  9. MasterMech
    There is nothing wrong with using wood for the aesthetics of it. Even if you don't really save money doing it. Life isn't always about the money ya know. ;)
    splitoak, schlot, thistle and 3 others like this.
  10. firecracker_77
    firecracker_77
    IL
    I love a fire as much as anyone. I very rarely run with the front door open. Even for that, the body of the stove still absorbs heat and will radiate it 360 degrees where a fireplace only does 180 degrees of radiant.
  11. B_Williams
    B_Williams
    Maryland
    It's really nice to just have a fire roaring in the evening. I usually have the doors closed if it feels like the rest of the house is getting cooler. There's a whole process of closing bedroom doors and fiddling with the fireplace doors but I worked it out this year (2nd yr in the house). An insert would be nice but it's hard to justify the price considering what we pay for NG. Some day...
  12. rookie1
    rookie1
    We added on to the house about 8 years ago and put in a masonry fireplace. I had a wood burner down the basement already. I put a fresh air intake setup on it for the fire to draw air for combustion. I think it works pretty good. :)
  13. nate
    nate Banned
    Palmer, AK
    We have "cheap" natural gas here too but I still save somewhere around 500-600 a year by heating with wood.
    Saving money is nice also its nice to not be dependent on natural gas and electricity for heating.
    If the power is out for a few days, I don't have to worry about being cold. Or if we had an earthquake that damaged the gas lines (quite possible)
    Scotty Overkill likes this.
  14. nate
    nate Banned
    Palmer, AK
    A fireplace will make heat. Yes it might pull air from outside into the house, but so does many wood stoves. Hmmm.....
  15. firecracker_77
    firecracker_77
    IL
    A fireplace is nice no doubt.
  16. Scotty Overkill
    I love the old colonial homes with the HUGE cooking hearths, they have a distinct charm and appeal of the days of old. We wanted that authentic look and feel, but wanted an efficient heater for the front half of the house as well. So I opted for a Napoleon NZ3000 (got a great deal online) and built a chase that mimics the old stone colonial fireplaces. The fireplace is VERY efficient, and VERY cozy, it pulls it's combustion air from the outside (OAK) which eliminates the drafts in your house........
    I even complimented the look with authentic hand wrought utensils and pots/pans from the 18th and early 19th centuries.......
    If you want the "open fire" ambiance, you can just open the doors and snap in the ember screen......
    it will take a while to get a full return on investment but we are already well on our way.....The kitchen stove (Napoleon 1900p) has already paid for itself and then some, but it's very nice to have constant, steady heat all winter, and to know that much hard work keeps my family warm during all those cold days and nights is a truly wonderful feeling.....
    Daryl, Deacon, splitoak and 5 others like this.
  17. firecracker_77
    firecracker_77
    IL
    Top notch...Looks beautiful!!! :thumbs:
  18. Scotty Overkill
    Thanks brother! That room ate a PILE of the past several years of my life, gave me a HEAP of grey hairs, and stressed beyond my threshold. ......hut the family absolutely LOVES it. So in the end, it was all worth it.
  19. firecracker_77
    firecracker_77
    IL
    That mantle is gorgeous too!!!
  20. Scotty Overkill
    Thanks.....it's a hand-hewn 200yr old pine beam from a barn I tore down that was built in 1868. It weighs around 300lbs!!
