Filled my oil tank
Discussion in 'The Wood Pile' started by fuelrod, Apr 25, 2018.
  1. fuelrod
    fuelrod
    Western Maine
    I've been wanting to make another "box" for the small cut off's and junk from splitting, they accumulate fast. My cousin called the other day and asked if I wanted an old 275g tank, I knew just what to do with it. I had enough "junk" around for this little wood dumpster.:D
  2. stuckinthemuck
    stuckinthemuck
    Pop a couple pieces out, test the moisture and see if you can get some kind of kiln effect with it... should heat up nicely in a sunny location....
    Hammy, basod, VOLKEVIN and 14 others like this.
  3. fuelrod
    fuelrod
    Western Maine
    I know it got pretty hot when I was painting it in the sun the other day.:thumbs:
    Hammy, basod, Elvisss222 and 14 others like this.
  4. Midwinter
    You could tip one of these puppies on it's side, 8043790100_32c3114369_b.jpg and have a pretty nice woodshed.
    Hammy, basod, milleo and 10 others like this.
  5. stuckinthemuck
    stuckinthemuck
    And probably get dinner while you’re at it! Did someone say something about puppies?:whistle:
  6. Midwinter
  7. Canadian border VT
    What a great idea.. As VT changed regs and all old one had to be pulled out.. Free old one every where..:sherlock:
    Hammy, basod, Woodslave and 8 others like this.
  8. fuelrod
    fuelrod
    Western Maine
    Yeah that's recycling. Add a little axle and you'd have a nice trailer for an ATV. A little cutting & add a 3 point hitch rigged up for the back of a tractor.............
    I'm full of cheap ideas:whistle: It seems the older tanks are tough enough to cut up (some) and retain their strength. This one was all 1/8" wall thickness.
  9. brenndatomu
    Leave a little oil in there and those uglies would be some dang good fire starter chunks! :D
    Hammy, basod, Woodslave and 11 others like this.
  10. Maina
    Maina
    Best use yet for one of those damm things!
    Hammy, basod, MikeyB and 10 others like this.
  11. FatBoy85
    FatBoy85
    Washington State
    Great idea, might have to steal borrow this idea for later. Makes perfect sense to have a bin like that that’ll gets well used in practical ways!
    Hammy, basod, Woodslave and 7 others like this.
  12. TurboDiesel
    :jaw:An oil tank full of wood. That pic should be your avatar!!!
    Thats a great pic!
    Hammy, Ralphie Boy, basod and 13 others like this.
  13. The Wood Wolverine
    I haven't called the oil man in a good 5/6 years. It's great.
    Hammy, basod, amateur cutter and 10 others like this.
  14. TurboDiesel
    Thats awesome!
    We used a 1/4 tank last year and less than a 1/4 this year. What a great feeling!!:dex:
  15. fuelrod
    fuelrod
    Western Maine
    Never thought about the irony, I like it even more now for it's symbolism! :thumbs:
    Hammy, basod, amateur cutter and 9 others like this.
  16. TurboDiesel
    Do it!:yes:
    :handshake:
    Hammy, basod, amateur cutter and 7 others like this.
  17. Backwoods Savage
    Great use for it.
    The last time I bought fuel oil was in 1978.
    Hammy, basod, amateur cutter and 8 others like this.
  18. brenndatomu
    I think the last time I ordered oil was 2007...and still have 400 gallons or so too! Need to get some of that used up so I can consolidate to 1 tank instead if 2...make a lil more room in the storage room.
  19. bear 1998
    bear 1998
    S.C.Pa
    Same here.....I keep callin to find the goin rate...last weak..2.49......waitin till its very close to 2 bucks...
  20. brenndatomu
    Too bad you are not closer to me...I'd sell ya 125-150 gallons for $2 per...
    Hammy, basod, VOLKEVIN and 5 others like this.
