Enviro Ef3 auger on time varies
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by steve45, Apr 12, 2018.
  1. steve45
    steve45
    Kentville N.S.
    Hi There,
    I have an Enviro EF3 that I just replaced the copper bushing as it was defective.
    But while I had it apart and have been watching it, I noticed another issue we have been having for some time.
    The auger will turn as usual for its 3 seconds and stop, then on occasion it will only turn for one second and stop, until it gets about 1/3 around then it starts up again back to 3 seconds turn.
    It is never in the same place, and it can be 20 minutes before this happens,also my dial-a-fire test's OK.
    I am wondering if it is the Auger timing control doing this?
    It works OK if we leave the dial-a-fire at 2/3 setting, just that the fire height will change on occasion.
    I have also replaced the motor, same issue.
    Wondering if anyone else has experienced this problem?
    ivanhoe and wildwest like this.
  2. steve45
    steve45
    Kentville N.S.
    Never mind.... it still seems to be randomly jamming up and working thru it.
  3. don2222
    don2222
    Salem NH
    If your auger shaft is 3/4” in diameter then I would put in the upgraded Nylatron Bearing & End plate. PP4010. The bearing is permanently lubricated and works much bette than the bronze oillite bearing. Dr Whitfield sent out a tech bulletin years ago to all his dealers and told them to do it right away!! Maybe he knew something? LOL
  4. ivanhoe
    ivanhoe
    Northern Ontario
    imacman likes this.
  5. imacman
    imacman
    Denver, NC
    x2
