Secondary burn on Kozy Heat insert
Discussion in 'Modern EPA Stoves and Fireplaces' started by Dakota Hoarder, Apr 17, 2018.
  1. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    I've noticed a significant decrease in secondary burn in my insert. I'm hoping it just need a good cleaning with the shop vac to clear it out a bit. I hav'nt been able to vac it for awhile due to 24-7 burns.
    Will a good clean and vac get the secondaries going again.
    Thanks FHC
    Horkn likes this.
  2. Horkn
    Yes, a light wire brushing of the burn tubes then a vacuum will help. Be careful with the shop vac though. Use the proper filter. Or your wife will never let you forget that time when...
    Dakota Hoarder likes this.
  3. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Yep, already got my backside in a sling for using the wrong filter inside... Won't be making that mistake twice! :doh::heidi:
    Horkn likes this.
  4. Unhdsm
    Unhdsm
    Bradford, Vermont
    Warmer outside temps will decrease secondary activity.
    LongShot, Horkn and Dakota Hoarder like this.
  5. blacktail
    blacktail
    PNW
    Warmer temps outside or a change in fuel.
