Homemade splitter
Discussion in 'The Wood Pile' started by old iron, Apr 8, 2018.
  1. old iron
    old iron
    sw va
    A freind of mine needed some help,so
    basod, FatBoy85, Hammy and 16 others like this.
  2. Maina
    Maina
    That’s some big stuff for a 4 way splitter head. She must have some oomph!
    basod, FatBoy85, Hammy and 3 others like this.
  3. amateur cutter
  4. Backwoods Savage
    Looks like a lot of heavy work there.
  5. bearverine
    bearverine
    Winchester, Indiana
    I love the lift.
  6. old iron
    old iron
    sw va
    Thanks fellows,this would have been a whole lot tuffer without the lift!
    basod, FatBoy85, Hammy and 2 others like this.
  7. haveissues
    haveissues
    Hudson Valley
    I recommend making a table to catch the splits. That way you just slide around the large chucks and don't have to pick them up.
    basod, Hammy, Thor and 5 others like this.
  8. old iron
    old iron
    sw va
    Havissue,been thinking about that a while now,I will have to extend hitch or make it removable,how is yours attached?
  9. haveissues
    haveissues
    Hudson Valley
    I'll take a picture for you later-it's hard to explain but it removes really easily. I just pop it off when I need to use the hitch. It makes splitting much easier.
    Hammy, Maina and Loon like this.
  10. haveissues
    haveissues
    Hudson Valley
    Hopefully this makes sense. I added a bar to each side, a rest in the front and the table hooks in. It takes seconds to pop on and off but is very stable.
    basod, Hammy, Thor and 2 others like this.
  11. old iron
    old iron
    sw va
    Haveissues ,now I got to make a table:salute:
  12. old iron
    old iron
    sw va
    Oh I forgot ,nice job on table
    I do have table to keep it from falling on ground, pull pin and slide it forward or remove also drilled a series of 3/4 holes in Beame so when I’m splitting shorter wood I drop a bolt and it stops ram from going all the way back 83A865D0-6920-4FB6-AC4C-2D655A71C399.jpeg 8911DBB1-DF28-457A-8BC8-FFE404940787.jpeg but like yours better
  13. jrider
    jrider
    Are you splitting for an OWB? Those are some big splits.
    Hammy likes this.
  14. haveissues
    haveissues
    Hudson Valley
    Very nice. The only other thing I would suggest is something to catch large rounds on the opposite side of the lift if that makes sense. Once you have a log lift it is hard to go back to using a splitter without.
    FatBoy85 and Hammy like this.
  15. FatBoy85
    FatBoy85
    Washington State
    Yeah that’s some heavy doooty splittin’ there Guy!
  16. Rowerwet
    Rowerwet
    Seacoast NH/MA
    That's why I split vertically, all it takes is a pickaroon to move them around on the ground
    Maina likes this.
  17. haveissues
    haveissues
    Hudson Valley
    I tried horizontal splitting and my back can't take it. After having a log lift and table I would ever split any other way.
