Deal of the day at Lowe’s!
Discussion in 'Chainsaws and Power Equipment' started by VOLKEVIN, Apr 8, 2018.
  1. VOLKEVIN
    VOLKEVIN
    Shenandoah Valley, Virginia
    image.jpg Lowe’s has a killer sale on the DR 3 inch chipper/shredder. List price was $799.00, and it is on the website for $359; But in-store it is only $180.00!
    Item # is 788400
  2. brenndatomu
    So how many you buy?
  3. Shawn Curry
    Shawn Curry
    Western NY
    Hopefully several, cause if they’re like mine you’re going to need a few if you want to get thru a tree in one day! :doh:
    I bought a small chipper with an 8hp engine a few years ago thinking I would use it on a couple of my brush piles. Gave up on that idea after the first day. I never use the thing anymore cause it’s just so slow. Fire is so much faster. :fire:
    Thought about using it to shred some leaf mulch for the garden though.
  4. VOLKEVIN
    VOLKEVIN
    They are out at my store, they’re checking to see if there’s one at another local store. I think it would be good for shredding leaf mulch-
  5. ironpony
    ironpony
    Mid Ohio
    I was going to post what Shawn did but I did not want to rain on your parade. so being he brought it up first I had the same results, great idea but way to slow, vibrates your hand numb, hopefully you have better results. Used mine few times and it sat in the shed for the next 8 years or so. I could not even give it away.
  6. VOLKEVIN
    VOLKEVIN
    Thanks for the feedback on it- guess I’ll pass. Dang it, thought I found a smokin’ deal!
  7. Horkn
    It's worth it for the motor alone.
  8. brenndatomu
    I knew the little 5 HP ones were a waste of time and money...but the 8 HP too, huh?
  9. 343amc
    343amc
    Northeast Lower Michigan
    I’ve got an older (late 90s) 5 HP chipper that was given to me. It works, but that damm thing is one of the most dangerous pieces of equipment I’ve ever used. I took a birch tree down back in 2013 and I spent more time unclogging the machine than I spent chipping.
    That said, it does a good job of shredding leaves.
  10. Horkn
    My neighbor has a 5hp simplicity brands chipper. He said I can use it whenever. I should take him up on it so it gets run more. I'll have to see for myself how badly it works.
  11. cnice_37
    cnice_37
    Noooooooo "good deals" are relative. Painful to use these things.
  12. eatonpcat
    Yep, I bought what I thought was a decent one at TSC years ago, clogged with almost every branch. They took it back the next day, which impressed me.
  13. amateur cutter
    Unless it's 40+ hp & tows behind a truck it ain't a chipper. Those little ones are good for mulching leaves & that's about it. Burn the brush!
  14. Eric VW
    Won’t buy. Nope. Especially with the responses here! :yes:
  15. yooperdave
  16. ironpony
    ironpony
    Mid Ohio
    problem is the engine probably has a tapered crank, not much you can use it with.
  17. ironpony
    ironpony
    Mid Ohio
    mine NEVER clogged it could not chip fast enough to clog.....11hp
  18. Barcroftb
    Barcroftb
    The Mitten
    Having spent more years than I care to say stuffing wood into a chipper, I'd like to think I can add a bit here. The issue with these little machines isn't necessarily the engine size. It's the restrictions at the chipping disk. In this case probably a flail style hammer mill set up. Decent for leaves and twigs and not much else. Probably worth the 180 if you have a lot of fall clean up.
    For hoarding purposes there are a few good options in the semi pro chipper segment. Most of those (wallenstein, dr, etc) 6" chippers will perform well in a non commercial setting.
    Dosko actually makes a 4" chipper that is surprisingly capable:
    Brush Chipper at Dosko
    Expect to pay a few grand though and still be slow. For most it's best to pile the brush up and torch it. If that's not an option pile it up and rent a 6" chipper for a day.
    Edit: to add video
    brenndatomu, VOLKEVIN and Chvymn99 like this.
