Stihl 441 crankshaft broken?
Discussion in 'Chainsaws and Power Equipment' started by Dakota Hoarder, Apr 1, 2018.
  1. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    image.jpg image.jpg image.jpg the crankshaft on my Stihl 441 sheared off while cutting some 18" maple.
    Through a little research it seems to be a pretty complicated and expensive repair?!!
    Is this something I sould attempt on my own (I can repair fuel lines, tune a carb, but never attempted an internal repair) or what should I expect to pay to get it fixed? Thanks in advance!
  2. dougand3
    dougand3
    North Alabama
    Replacing crankshaft is the most difficult repair...total disassembly and split the case, bearings and seals. Bet a shop would charge $200+. May be a good time to learn - lots of youtube instructions.
    Chaz and Dakota Hoarder like this.
  3. 94BULLITT
    94BULLITT
    Frederick County, VA
    Ouch, that is going to require a full tear down. How low do you run your depth gauges?
    huskihl and Dakota Hoarder like this.
  4. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Thanks, that was my assumption, u checked on YouTube and didn't find anything very useful. If you have a good vid let me know!
  5. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Not lower than specs. I baught it used from a rental store. Wondering if renters jamed the chain break on? Would that cause crankshaft failure?
  6. 94BULLITT
    94BULLITT
    Usually a broken crank is from depth gauges that are too low or a chain that is grabby/ chatters. With it being a rental saw who knows how it was used.
    Sent from my SM-G950U using Tapatalk
  7. Armbru84
    Armbru84
    Sparta, Michigan
    If you decide to tare into it let me know. I have a set of bearings, seals, and some other parts for sale.
    Chaz, huskihl and Dakota Hoarder like this.
  8. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Thanks, you have a crankshaft?
    Chaz likes this.
  9. Armbru84
    Armbru84
    Sparta, Michigan
    Nah I don’t have a crank.
    Dakota Hoarder likes this.
  10. huskihl
    huskihl
    A 441 isn't the simplest saw to tear down. If you do it yourself, take lots of pics as you disassemble so you have a reference when you put it back together.
    Armbru84, Chaz and SAWMIKAZE like this.
  11. 94BULLITT
    94BULLITT
  12. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    I checked at one dealer and they want $345 just for parts:hair:!!
    $100 for a used one sounds good, to bad the one one the link is sold out!
    Anybody have thoughts on an after market crankshaft?
  13. huskihl
    huskihl
    Most are a little uneasy about recommending AM parts. Especially a crank. But a member from OPE has been milling with a 460 or 660 with a Raisman crank for a few years with no issues.
    Chaz, Dakota Hoarder and 94BULLITT like this.
  14. 94BULLITT
    94BULLITT
    I got a bad crank in my 660 kit. I just it rebuilt. It sounds so much better.
    huskihl likes this.
  15. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Ok, buying a new 441 crankshaft from dealer for $350 is out of the question.
    I have a guy that I've traded and purchesed saws from that does good work that will repair the saw for a reasonable price if we can find a good used crank, or reliable after market.
    All leads on used or quality after market would be greatly appreciated!
    Thanks FHC
    brenndatomu, Chaz and dougand3 like this.
  16. huskihl
    huskihl
  17. huskihl
    huskihl
  18. Fifelaker
    Fifelaker
    Fife Lake Mi.
    Kevin that is a Raisman crank in my 440. Mastermind recommended it after he built the saw you mentioned.
  19. Fifelaker
    Fifelaker
    Fife Lake Mi.
    Ted is good people, I would buy the Warped5 crank.
  20. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    thanks guys! I'm currently checking with my repair guy to see if he can make it work. I hope it works out! I don't have any need for a nice 441 parts saw!
    brenndatomu and 94BULLITT like this.
