Pellet brands
Discussion in 'The Pellet Bag' started by BrowningBAR, Mar 19, 2014.
  1. subsailor
    subsailor
    Winthrop, Maine
  2. imacman
    imacman
    Denver, NC
    IMO, more. The more BYU's a certain pellet produces, the less time and less pellets needed to heat the h2o. Poor pellets will just make you burn more to heat the water to a certain temp.
  3. krooser
    krooser
    Waupaca, WI
    You are also going to find that softwoods burn hotter than hardwoods… I know that's blasphemy to a wood burner but true...
  4. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    Not at all. I'm used to soft wood burning hot, but fast. Can I assume correctly that the softwood pellets burn faster, as well?
  5. jtakeman
    What seems to effect how long a hopper load lasts is the size and density of the pellets. I got similar run times out of both if they were equal in both size and density.
    What gets most thinking that the softies burn quicker is most softies are a lot denser compared to the average hardwood middle of the road not so dense pellet. I have seen the good hardwoods burn faster than the softies and I'm pretty sure it was due to density/size.
    imacman likes this.
  6. will711
    will711
    Pocono Mts.
    BrowningBAR likes this.
  7. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    I notice the BTU per pound stat. It looks like the price is based on that. Is that true or just coincidental for this example?
  8. will711
    will711
    Pocono Mts.
    That seems to be the way it works for them higher BTU's more $ ,but at the same time all 3 of the cleanfire brands come from the west coast more shipping costs included .
  9. Lousyweather
    Lousyweather
    basically doesn't it all break down to BTU's per pound? The stove has no idea what its burning, but, (in most cases), regulates its heat based upon the room sensing probe......so, more heat per pound = less pellets used = longer burn time (regardless of softies versus hardies)
    imacman likes this.
