Pine clearing for the new garage build
Discussion in 'The Wood Pile' started by thewoodlands, Mar 7, 2018.
  1. thewoodlands
    thewoodlands
    Thanks Canadian border VT , I'm glad I did it that way we'll have room for more branches by the fireplace.
    Chazsbetterhalf, Maina, basod and 5 others like this.
  2. Scotty Overkill
    Looking good, thewoodlands! I'm looking forward to this project. Hoping to do a pole building myself later this summer, if the finances allow.
  3. yooperdave
    Looks like a strong start on the project.
    Add me to the list of those eagerly waiting for the build!!!
  4. thewoodlands
    thewoodlands
    We have a contractor doing it except for a few things like tree removal, stump removal and we think we have enough sand on our property that we won't have to buy it. You don't have to answer but if you did a job of just dropping pine like what were doing, how much per tree would you charge.
  5. thewoodlands
    thewoodlands
    Thanks yooperdave , I should've started about a week ago but I picked up a job testing recliners in our house! :thumbs:
  6. Well Seasoned
    I've paid $100 per tree to just have it dropped.
  7. NH mountain man
    NH mountain man
    WMNF N.H.
    That's an important job too. Sometimes we need a day of downtime, you know, to plan our attack! :saw:
  8. Scotty Overkill
    It really all depends on if we had to climb them, rig them, clean them up, etc....
    I'm probably going to have a Amish crew put my building up too, I'll do the concrete and interior work.....
  9. billb3
    $1700/1800 is a day rate for one crew here. 4 guys, one climber, one crane/bucket truck , a bobcat, a chipper and truck. CODB here is nuts.
  10. billb3
    We have a section of the property that was cleared 60 years ago and it's predominately pine like that, a pine grove if you will, and the trees are all about the same size as there and looks similar.
    FatBoy85, Maina, thewoodlands and 3 others like this.
  11. Backwoods Savage
    You definitely should have enough sand there. Better than having to buy it.
  12. thewoodlands
    thewoodlands
    We had a late start today so we only put one on the ground but the area is all cleaned up ready for another felling.
    We have 378 hours on the Mahindra 4540, I think it goes back to the dealer for a checkup at 500 hours.
  13. thewoodlands
    thewoodlands
    Tomorrow number one will come toward number two and later tomorrow or Monday number two will go toward
    We have some pine rounds on the ground just below number one so I'll need to clean that up.
  14. Well Seasoned
    Great pics woody.... nice work! :yes:
  15. yooperdave
    I'm sure you already thought about it, but get rid of all the trees within striking distance that look questionable for the next few decades.....
    I did this at the cottage and was sure glad to get rid of a mature large aspen....that had rot going on about 30-35 feet up in it!
  16. thewoodlands
    thewoodlands
    We're getting there, I just wish we had more room where I could drag the logs to a different work area with the tractor.
    yooperdave , once we get the pines down where the garage is going a bunch more in striking distance will come down. The original plan is to get the pines down where the pad will go and some on the east,west and the south of the garage, we'll see what's left that will need to come down.
    The good thing about getting the old trees down will be the new trees that will grow or get planted, this area is on the northside of our house so it gets plenty of sun.
    I'm thinking that we'll be taking down close to 30 pine trees.
  17. thewoodlands
    thewoodlands
    Today was the last day for 10 percent off coupon so we headed to town for dog food and a few other things. Once we got back it was time to plow both driveways of the snow we received overnight, after that I came in for lunch and a coffee and then took a seat in the recliner........when I woke up it was 4:30 so nothing for tree work was done today.
    With 4-8 inches of snow forecast starting tomorrow night, I'm not sure if I'll get a tree down before the snow hits or burn what's left by the fireplace.
    I did grab two more d-shackles and a few extra snap rings so I could fix our second snatch block, we can double our pulling power if needed. I almost bought a larger and longer cable but didn't, but if we need it we'll run back in.
  18. Well Seasoned
    Recliners are good for that. I think you'll have time if you start early. Gonna get pretty cold overnight so an early start maybe out. :shiver:
  19. thewoodlands
    thewoodlands
    I think our low is 19 so it won't be that bad, the first trees I cut for this job are still on the ground in rounds so I might clean that up and then burn the branches from the other day.
  20. Backwoods Savage
    Have you ever considered using rope vs cable?
    FatBoy85, Maina, savemoney and 2 others like this.
