  1. CleanFire
    CleanFire
    Sure thing Steve, the units here are only a few months old ( Nov. '17 ), so I wouldn't be surprised if that was a factor also over time,
    the 1st PFC UPS I had on the stove was only a 1,000 watt unit - stove startup surge @ 450+ watt was tripping it / causing it grief, upgraded to the 1,350 watt in '16, seemed to work ok / ended up re-tasking that unit shortly after end-of-season,
    the current new 1,500 watt units -
    (1) for stove only / no other devices,
    (1) for entertainment center (TV / DirecTV / BluRay player / Linksys Router, Netgear switch) are doing good, so far.
    If you can plug your unit in direct to 110v output @ the GenSet, maybe that will give you better info. on the line voltage / Hz output .. we always run 240v switched -> into house service here.
    I have the printed instructions for most of the Cyberpower UPS units available, if you need any info., give a shout - I'll be checking in regularly today.
    Kind Regards, Rob
    ivanhoe, imacman, bogieb and 2 others like this.
  2. CleanFire
    CleanFire
    Was typing when you posted - glad to read this Steve! :thumbs:
    :cheers:
    ivanhoe, imacman, bogieb and 3 others like this.
  3. ttdberg
    ttdberg Pellet Pig
    CT
    According to the mechanical clock on the stove, we lost power just before 1:00pm yesterday. Eversource left a broadcast message a little while ago saying power would be restored to most households by 9:00pm Sunday. More heavily impacted areas would take longer. Got a feeling we're in one of those areas.
  4. will711
    will711
    Pocono Mts.
    That's not good TT , hope you get it back soon
    Luneyburg, ivanhoe, schoondog and 6 others like this.
  5. CleanFire
    CleanFire
    x2 - stay safe down there TT. :yes:
    ivanhoe, imacman, Eric VW and 3 others like this.
  6. slvrblkk
    slvrblkk
    Northampton, PA
    I just have a cheapie Champion and like most the voltage and frequency run higher to compensate for more load then it drops down into more "normal" range with higher load. The genny actually works great but I probably should have bought a larger one. Being I deal with generators and UPS' is as part of my job you think I would know better. :picard:
  7. will711
    will711
    Pocono Mts.
    True ,but like most of us here we Cheap :whistle:
  8. slvrblkk
    slvrblkk
    Northampton, PA
    Who? :whistle:. :rofl: :lol:
    ivanhoe, imacman, Eric VW and 4 others like this.
  9. CleanFire
    CleanFire
    Cheep works - if I could get a couple of the squirrels that were climbing all over the house last night (all night :picard:) on a treadmill turning a motor to power a light bulb ... I'd be a happy guy. :thumbs:
    Steve, I wouldn't sweat it at all - if the UPS is protecting the stove from any utility power issues, and the stove runs fine on straight GenSet power, that's a beautiful thing right there. :yes:
    Heck, the fact it starts & runs when you need, it is a beautiful thing. :thumbs:
    I see those Champion-branded Gen Sets pretty regular at Ocean State Job Lot when I visit: they look well built, and easy to operate.
    * You could always 'borrow' a 40Kw or so Diesel GenSet from work .. :whistle:
    badbob, ivanhoe, imacman and 5 others like this.
  10. slvrblkk
    slvrblkk
    Northampton, PA
    Hmmmm.....very good point :whistle:
    My boss - "hey Steve O, what happened to the 85KW genny on the trailer?"
    Me - "I don't know :whistle:"
    :D
  11. jtakeman
  12. bogieb
    Hope that was the old snow blower and not the new one!
    I got home from my class and cleaned up the berm at one end of the driveway from the road plow, then the berm at the other end from the roof dumpage. Happy to report that everything in between had melted - yay for blacktop since it didn't actually get all that warm here temp wise.
    ivanhoe, imacman, CleanFire and 3 others like this.
  13. CleanFire
    CleanFire
    That's good news JT - hope it doesn't take too long for them to get power back there. :yes:
    bogieb, ivanhoe, imacman and 2 others like this.
  14. CleanFire
    CleanFire
    Nope, the new one. :picard: ...
    It's called a Toro for good reason - 'cause trying to get any kind of tool back at the impeller, without being 'gored' & shredded is damm near impossible.. :headbang: ... gotta remove the shear pins, & disengage auger gearbox from the impeller assembly tomorrow am. so I can spin the impeller backward, Yay ! Sigh. :(
    badbob, bogieb, ivanhoe and 3 others like this.
  15. gbreda
    gbreda
    NH
    I had to completely disassemble my honeys Troy Bilt when the dog runner wrapped around the auger shaft. Whole front end had to come apart :headbang:-Google was my friend that day and McGiver was called upon to make parts from the hardware store that were not readily available at the small engine shop
    savemoney, CleanFire, bogieb and 4 others like this.
  16. schoondog
    schoondog
    Dutchess County N.Y.
  17. will711
    will711
    Pocono Mts.
    Them little guys is having some fun . Do you know which one you're keeping ?
  18. CleanFire
    CleanFire
    PDF copy of the Service Manual, check.
    Waay too many cups of coffee this a.m., check.
    Every tool in the arsenal on-deck, including cold chisel and a Big 'ol Hammer, check.
    If I can change out the suspension on the '00 Camry ... I can do this.. Without destroying it beyond all recognition.
    (Repeat to myself. And.. Repeat.)
    :yes:
    * I'll let you know when I get back from the Hardware Store, G. :picard:
  19. schoondog
    schoondog
    Wife knows. I guess she is the darkest female. Rosie is gonna be the name I think. I can't pick her out on the video.
    Doggy
  20. ivanhoe
    ivanhoe
    Northern Ontario
    Sooo cute at that age, enjoy the moment:thumbs:
