Picked up a 2000 F350 Powerstroke
Discussion in 'Chainsaws and Power Equipment' started by Unicorn1, Mar 1, 2018.
  1. Unicorn1
    Unicorn1
    Amarillo, TX
    It came with a stack of repair receipts, anyone looking for a Omaha utility bed setup? I'm looking for a used flat bed, I see a few local.
    brenndatomu, fuelrod, J. Dirt and 5 others like this.
  2. Blstr88
    Blstr88
    Pics!
    Love the old 7.3 powerstroke, awesome engine. How many miles?
  3. Unicorn1
    Unicorn1
    Amarillo, TX
    248K, hoping to get another 100k out of it.:)
    Anything special I need to know when looking for a used flat-bed for this truck?
    J. Dirt and wildwest like this.
  4. wildwest
    Cool!! This one (1999 F250) is well over 500,000 miles, no doubt you will get atleast another 100K
  5. Mwalsh9152
    Mwalsh9152
    Pelham NH
    Make sure it's for a pickup chassis. The frame is narrower on the cab and chassis trucks.
  6. fuelrod
    fuelrod
    Western Maine
    The old 7.3's don't need that newfangled "designer" fuel either. They're just fine with heating oil. Off road use only of course. :whistle:
  7. Unicorn1
    Unicorn1
    Amarillo, TX
    We picked this up today for $400. I don't see a data tag so it might be home made, does have spring loaded hidden rectangle doors on the left side so???
    OhioStihl, brenndatomu and Horkn like this.
  8. bang
    bang
    South central Indiana
    Another 100000 miles shouldn't be a problem, I have 475000 on my 03 and still not adding oil between oil changes.
    brenndatomu likes this.
  9. ironpony
    ironpony
    Mid Ohio
    be prepared to add to them................sorry could not resist.
    good luck with the new toy, Pics??? you know the rules.
  10. brenndatomu
    Hopefully it has had the injectors replaced already...that's a pretty common (and pricey) repair around 250k...unless the PO was completely anal about oil changes...then you may get another 50-100k outta 'em. If you ever need to pull the valve covers (glow plugs) do yourself a favor and look up the "quarter trick"...basically Ford found that the plastic multi-connector that is built into the valve cover gasket for the glow plugs and injector wiring can work loose and cause all kinds of problems. They made a shim to jam under the connector lock tab...but people found out that a regular old quarter fits perfectly...I'm cheap so I used a couple flat washers I had laying around...also fit perfectly. :D
    That looks like a heck of a score on that flatbed...around here used flatbeds bring premium money because everybody is wanting them to replace their rotted out factory beds. I had to pay $400 for a flatbed that is not as nice as that one...one like that here would be $800-$1000 more than likely. Before everybody's older Superduty beds started rotting off you could find $2-400 used steel flatbeds without even trying too hard...
