Here She Comes
Discussion in 'The Wood Pile' started by Ralphie Boy, Feb 23, 2018.
  1. TurboDiesel
    Nobody has to tell me the roads will be slippy when it snows....
    If it wasn't for sensatioalizing, the weather channel wouldn't have anything to say.
  2. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    What a difference a day makes! Yesterday the water was a few feet from the stacks and several feet from the white shed. Today the stacks and shed are in the water.
    Trouble is my Kubota is in the left side of the shed and my new splitter is in the right side! The plan was to get them out today, because the rain is over for a few days and the river wasn't cresting until Wednesday, and bring them up to the house and leave them outside. Oh well the best laid plans of mice and men.....l think my losses are going to be greater than I though....
    Well Seasoned likes this.
  3. Midwinter
    Oh no! Might the water level still be below the engines?
  4. Ralphie Boy
    Ralphie Boy
    Looks like it. But the second problem is my kayaks, which are out of the picture, have floated about 50 yards out where the water is too deep to walk out and retreave them. I've got to get to a friend and borrow his to retrieve mine and to get into the shed. By then; who knows!
  5. Well Seasoned
    Sorry to see all of this Ralphie Boy. I hope you make out ok.....
  6. Ralphie Boy
    Ralphie Boy
    Well, the house is safe and the wife and I are safe and in the end that's all that really matters, isn't it.
    fuelrod, OhioStihl, HDRock and 6 others like this.
  7. yooperdave
    Huh?
  8. brenndatomu
    Can you still get them out?
  9. WeldrDave
    Man Ralph boy, I'm sad to here all this! I'll pray things work out for you. Is there anyway to get the Kubota to higher ground? As expensive as they are, I think I'd figure a way to get to it.
  10. Ralphie Boy
    Ralphie Boy
    I'm headed down in a few minutes to find out. Ahhh man, nothing like an early morning swim!:rofl: :lol:
    HDRock, Chaz, yooperdave and 6 others like this.
  11. brenndatomu
    That would be fun! Logs cut and loaded on a barge at walt s GTG, floated down to Ralphie Boy s to be cut at GTG part 2! :thumbs:
    (just hafta make sure eatonpcat doesn't fall in the crick!) ;)
    HDRock, Chaz, TurboDiesel and 4 others like this.
  12. Ralphie Boy
    Ralphie Boy
    Well, the Kubota is safe by a couple inches but the splitter motor was submerged for probably 10 hours but the ram stayed above water so its saved. Nothing a new motor won't fix. Some folks lost their and all their possessions.
    I'm no mechanic; anyone close want to help me replace a splitter motor?
    HDRock, Chaz, Well Seasoned and 6 others like this.
  13. bocefus78
    bocefus78
    Drain the oil, let it drip out for a day to get all the water out. New oil. Drain the bowl on the carb.
    Check hydro oil for water also. The big cap on the tank has a pinhole in it for a pressure relief.
    Then fire it.
    If no fire, probably needs a coil.
    I doubt it needs a motor.
    Glad Yall are safe. Thats what matters.
    WoodPirate, HDRock, Chaz and 6 others like this.
  14. Ralphie Boy
    Ralphie Boy
    That's my plan. It will either work or it won't.:salute:
    HDRock, Chaz, Well Seasoned and 5 others like this.
  15. WeldrDave
    Bocefus said correctly but let me add some things if I may... I'm no super mechanic but i've seen "Alot" of outboards under water and brought back to life fairly easy. What we do here is after you drain the oil, fill the whole motor with K-1 or Diesel and slowly pull the engine around "not fast". Blow out the gas tank and lines and dump some Isopropal or denatured Alcohol in the carb and tank, rinse then blow out the engine everywhere with compressed air real well. Let the engine dry off a bit and give it a light spray with something like WD-40 of as such. Add fresh oil, fresh gas and it "should" start right up, That motor should be fine. I've seen this many times here on the coast. I had a lawn mower several years back we did the exact thing to, still running to this day! :)
    HDRock, Chaz, Well Seasoned and 7 others like this.
  16. leoht
    leoht
    Victoria. Australia. Earth.
    I would like to add
    - replace air cleaner element,
    - drain and clean fuel tank,
    - clean and dry spark plug,
    - You can even flush the engine with diesel fuel to wash out some of the muddy water.
    That motor should be ok Ralph, I have seen many dirt bikes get dropped in river crossings or deep bog holes (including my own once) and we always got them going again!
    Fanatical1, HDRock, Chaz and 8 others like this.
  17. WeldrDave
    Very Good point, forgot that one!!:yes: It'll run again! Take your time with it.
  18. billb3
    The National Weather Service has been sued for not predicting weather resulting in loss of life.
  19. Backwoods Savage
    Sure feel for you Ralphie Boy. Hope the water does not come up more but perhaps you should get that tractor out just in case! Good luck on the splitter. I think that wood will be fine if it doesn't float away.
  20. Ralphie Boy
    Ralphie Boy
    It's out. The water missed the motor by a couple or inches. The new splitter's ram stayed out but the motor was under water all night. Only about 15 hours on it.
