husky 61 compression?
Discussion in 'Chainsaws and Power Equipment' started by chuck172, Feb 17, 2018.
  1. chuck172
    chuck172
    sussex county nj
    I've been having a hard time starting my chainsaw. Compression is 90 psi. Too low?
    TurboDiesel likes this.
  2. walt
    walt
    north central ohio
    I don't think it is going to start,takes about 120 to run weak. I'm sure some of the mechanics will chime in soon
  3. huskihl
    huskihl
    Take the muffler off and check the piston for vertical scoring. If it's still smooth, the rings are possibly worn out. Easy saw to work on
  4. HDRock
    I don't use my 61 much anymore but compression is 160
  5. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    Good chance the ring stuck on the exhaust side. If it's not scored real bad it's a relatively easy fix.
    The 61 is a good basic powerhead.
  6. TurboDiesel
    Welcome to the club, chuck172 !
    walt likes this.
