I want something to clear the snow with
Discussion in 'Chainsaws and Power Equipment' started by Jack Straw, Feb 14, 2018.
  1. HDRock
    Maybe this will help ya decide :)
    Well Seasoned, Hammy, Eric VW and 6 others like this.
  2. Stinny
    Yes, yes and yes. As you said... heat-check... your honey can handle it easily-check... you'll use it for other things too-check. And, I know I'm wicked good at spendin' other folk's money... so... there's that... :emb:... YES... :BrianK:
  3. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    “Honey, Stinny said we must get one of these!” :thumbs:
  4. thewoodlands
    thewoodlands
    If you go with the Bota in the pic, I would get chains for the back tires. I saw that same Bota but with a plow on it being pulled out because he didn't have chains.
    Our Rhino would be good plowing in certain areas without the chains and pretty much useless in other areas in the woods without the chains.
  5. Stinny
    Hehehe... that'll work just fine... :whistle:
  6. eatonpcat
    Love the Toolcats, but they are around $60,000 new (I think).
    Well Seasoned, Horkn, Hammy and 5 others like this.
  7. Brian72
    Brian72
    PA
    I'd take a blower over a plow any day and the side by sides come in handy for property maintenance. I don't think you'd ever regret buying that machine.
    Sent from my Moto E (4) using Tapatalk
    Well Seasoned, Hammy, Eric VW and 3 others like this.
  8. Jack Straw
    Jack Straw
    My concerns with a blower is heavy, wet snow and visibility on windy days. They are a lot faster than a plow and with dry snow you can you can wait until the end of the storm to clean up.
  9. Birddogtg
    Birddogtg
    Central ohio
    I have a Polaris 900 ranger that comes in real handy around the farm but the Kubota is even better because of the hydro dump and weight capacity but I would get a plow over the snow blower
  10. Stinny
    Ummm... you're still gonna have your tractah though... right? When the occasional pita frozen block type snow happens... you use the bucket to bust up the snow... and the blower to remove... with coffee in hand... :dancer:... and, if possible, only blow heavy wet snow the following morning when it's re-frozen a bit... to blower launch grade snow... ;)... visibility, inside an enclosed cab, is a moot point... (you won't care cuz you're warm and dry... :coffee:)
  11. LodgedTree
    LodgedTree
    The biggest thing with a side by side, especially if you want your wife to use it, is to be SURE it has power steering. Without it, they can be a bear to steer. Add a snowblower and it would even be worse.
    I say this from real world experience.
  12. Jack Straw
    Jack Straw
    You’d have to pry the tractor out of my cold, dead hands!
    Stinny, Well Seasoned, Horkn and 4 others like this.
  13. Backwoods Savage
    Come on Larry. You aren't that old yet.
  14. Eric VW
    Well?! Have ya bought the danged thing yet Jack Straw ???!!! :thumbs::rofl: :lol:
    Ya could just move souf....
  15. Screwloose
    Any regrets to buying what you really desire will end when the payments stop. If you compromise to much the regrets will last much longer.
  16. Brian72
    Brian72
    PA
    My small Ariens does well with heavy wet snow. I don't think it would be a problem with the setup you're looking at. I can shoot it 50 feet and put it where I want it. No more frozen plow piles to deal with. It's also better in the major storms when it gets too deep for the plows.
  17. savemoney
    My body is busted up. Arthritis and too fat. I keep trying to win the fat battle, but I am such a yo-yo with sticking with it. I'll go a year, then fall back. Now beginning to think about a surgical intervention. My brother had that done, so did my daughter. Brother lost too much weight, daughter is in the right range. Nephew had the sleeve done and he is doing just fine.
  18. Screwloose
    I wish I had a blower instead of a plow on my tractor. I get frustrated when the only snow left is in the mounds surrounding my driveway.
  19. chainsawsoldier
    chainsawsoldier
    NE Kansas
  20. Horkn
    A blower definitely works better than a plow. Wet snow, that is no issue for a blower, not if it's a 2 stage.
