52I Harman insert
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by artc, Jan 28, 2018.
  1. Lousyweather
    Lousyweather
    ?.....ok, but the igniter isn't centered anyhow, its on the left side of the burnpot......
    CleanFire, imacman and ivanhoe like this.
  2. Rich250
    Rich250
    Berks County PA.
    appearantly you gotta get em lit first though :D
    CleanFire, ivanhoe, imacman and 3 others like this.
  3. Lousyweather
    Lousyweather
    yup......owner had to have been doing something wrong! :D
    CleanFire, ivanhoe, imacman and 2 others like this.
  4. jtakeman
    :whistle:
    CleanFire, ivanhoe and imacman like this.
  5. unbidden
    unbidden
    RI
    Smack in the middle on my 52i. At least as I remember, I'll take a look.
  6. Lousyweather
    Lousyweather
    depends on which setup you have, but the cradle-type holder (older style) was to the left, facing the burnpot.....and the newer-style integral burnpot, same dealio.....the picture is upside down, so it looks like the igniter is toward the bottom, but installed, the bottom of this picture is to the left......hope this helps
  7. artc
    artc
    Rocky Hill, CT
    I haven't had a lot of time to check out my ignition problem and was running in stove mode for a couple weeks. don't have a draft gauge either, or how to set it up.
    Changed two things thinking airflow has to be the problem: removed the screen I had over the 4" outside air intake to eliminate any constriction at this point. noticed that a couple of cocoons were on the screen, further reducing air flow. did not improve ignition much.
    Door gasket dollar bill check: well all I had was a $100 so I had to use that! loose in several places. adjusted the latch as far to the rear of the hole as I could get - that tightened it up a fair bit. There's really no adjustment, just the slop in the hole.
    stove ignites on the first pellet feed stage reliably. problem solved temporarily. I need a new door gasket for a more permanent repair.
    thanks for all the info!
  8. PelletHound
    PelletHound
    SE Ma.
    What does that gear thingy do?:sherlock:
    CleanFire, jtakeman, ivanhoe and 3 others like this.
  9. PelletHound
    PelletHound
    SE Ma.
  10. ivanhoe
    ivanhoe
    Northern Ontario
    Probably a extra pic which wasn't intended to be shown :smoke:
    A subtle way of saying he's a gearhead :rofl: :lol:
    CleanFire, jtakeman, artc and 2 others like this.
  11. ttdberg
    ttdberg Pellet Pig
    CT
    Spacely sprocket.
    CleanFire, jtakeman, imacman and 4 others like this.
  12. ttdberg
    ttdberg Pellet Pig
    CT
    :thumbs:
    Gratuitous cog shot?
    CleanFire, imacman, ivanhoe and 2 others like this.
  13. jtakeman
    Geez, Now the stove knows you got cash!! Why we only use $1.......
    :emptywallet:
  14. Lousyweather
    Lousyweather
    well, it IS a Harman....do you really believe any test on a Harman would work with a measly $1 bill?!
    Take an ugly guy, send him in the bar, see how much "game" he has. He's probably leaving alone. Take that same guy, have him pull up in a hot car, stick a $100 bill hanging out of his pocket.....chick magnet!
  15. CleanFire
    CleanFire
    A big +1 Dollar to that JT! :thumbs: It's the other 'stove operator' I'm more concerned with though. :whistle:
    Your stove looks like a ATM in that pic. :D
    LW is taking his Harman stove w/ him to the bar. :thumbs:
