Need advice from the chain sharpeners…
Discussion in 'Chainsaws and Power Equipment' started by Stinny, Mar 19, 2014.
  1. Stinny
    You high time commercial guys know what you're doing from experience sharpening chains. Is the $$$ and time worth it to get into sharpening my own chains with an elec grinder sharpener?
    Oliver1655, DexterDay and Pallet Pete like this.
  2. jrcurto
    jrcurto
    SW Connecticut
    I started using a crappy Chicago Electric sharpener from Harbor freight. Had to order a 3/16 wheel from Oregon for my chains but it definitely works and puts a super edge on the teeth. You have to set the grinder up on a stable bench that's well lit and really get close and fine tune the adjustments for a gentle clean pass on the saw teeth. Clean the chains in simple green and dry well. I did a few of my neighbors chains and he is very pleased. I am definitely investing in a better model once I feel confident.
    Oliver1655, DexterDay and Stinny like this.
  3. Pallet Pete
    Pallet Pete Moderator
    Ovid
    If you have a good place to start out then yes but I will say it is a LOT of work. For commercial chain grinding it's all about time.... My old HF unit there was no way I could efficiently do it. Right now I have a timber tuff and one chain back to factory edge or better in about 9 minutes rakers and all. That's slower than a lot of guys but I need to switch wheels to do the rakes as I only have one unit. Two is best! Both dedicated one for rakers one for teeth. My charge is $5 a chain which doesn't sound like a lot but when you do 30 or more chains a week it adds up fast. I will be expanding into online / mail order sharpening very soon as well which is a whole nother beast... It can be worth it but it takes a lot of practice first as you probably won't be able to try it on a saw to be sure it's done right.
    DexterDay likes this.
  4. Stinny
    Thanks Pete. One skill I've learned, that is most important when I'm doing projects… and, that's when it's time to get someone more skilled than I am. My dam eyes are failing fast and it's a new thing for me. I've been able to focus on stuff clearly at close range, all my life. No more, even with glasses. All of the posts and vids here have shown that a good eye is as important as all else. If you want my sharpening biz, let me know. I'd wait until I had 10 to sharpen at a time. I think I can pass on getting yet another machine for the shop.
    Oliver1655, w8ye and Pallet Pete like this.
  5. MasterMech
    Are you picky about your chains? The answer is the same.
    Lots of good filing jigs available too and that's about feel more so than vision. But without good vision, corrected or otherwise, you are going to have a hard time learning a new skill like sharpening regardless of your method.
    Stinny, I sure hope you've talked to a Dr about your failing vision. It can be a sign of other troubles with the body. Good luck brother. :yes:
    Oliver1655 and Loon like this.
  6. Stinny
    Thanks Mech. When I say "fast", I mean over the last 2-4 years, I've noticed a difference. I wore glasses when I was younger. I'll be 60 next month, so eyesight changing is not a real surprise. Both of my folks had the same issues too.
    Looking at this computer screen all the time prolly ain't helpin much… and, oh yeah, I got troubles with the body alright… :whistle:
    Pallet Pete and MasterMech like this.
  7. swags
    swags Moderator
    I have the same unit as Pete, just got it and haven't done much with it yet but it is way better then the mini Oregon I had. Does a good job on the chains. And comes with three wheels to do any chains I have along with the rakers. Only tng I don't like is the guard is a bit of a pain to take off to switch wheels.
  8. chris
    I run 3 grinders one each for front/back or left/ right cutters ( however you care to call it) and the third unit just for depth gauges. I do a lot of chains ( commercial ) so constanty swinging the vise back and forth wears it out, burned out a few motors, lots of switches, and broken a bunch of return springs over the years.
  9. DexterDay
    I have the Timber Tuff just like Pete and Swags and I love it. It's an Oregon Knock-off. Northern makes the same grinder as the Timber Tuff, but it's Red. They can be had for around $100 on sale.
    As noted above, comes with 1/8", 3/16", and 1/4" wheels. Has an adjustable head angle (big selling point over the cheaper units), and also cast iron construction (not plastic like the cheaper units).
    Overall, a solid unit for the money.
    Stinny likes this.
  10. chris
    I would highly doubt your statement of cast Iron , cast material, yes. Even the 511ax by Oregon is not cast iron. Perhaps a cast steel light weight alloy.
  11. MasterMech
    My USG is cast aluminum, which what most grinders that I have see are made from?
  12. w8ye
    w8ye
    Mansfield, Ohio
    My Oregon 511A is cast aluminum
  13. chris
    Not having seen a timber unit in person I didn't want to specify a particular material, 511ax is also a alum. alloy of some type.
  14. w8ye
    w8ye
    Mansfield, Ohio
    Yes, it is a high zinc content aluminum that is diecast.
  15. chris
    AKA = POT Metal
    w8ye likes this.
  16. DexterDay
    Cast construction. Yeah. Likely aluminum.
    My mistake. . It's not Plastic. I know that much. ;)
  17. Firewood Bandit
    Firewood Bandit
    The Tecomec clones for around $100 aren't too bad with a little tweaking.
    I us the Tecomec for rakers and the Oregons 511AX for cutters. (Oregon is made by Tecomec)
    Stinny and swags like this.
  18. w8ye
    w8ye
    Mansfield, Ohio
    The grinder on the left may have been sold by Tecomec but it is made in China. It looks like a copy of the Oregon 510? I'm not trying to say it is not as good as the latest Oregon/Tecomec 511AX style one on the right but it is just a little different. What I'm trying to say is that some Tecomec's are almost exactly like the corresponding Oregon except for the color - made in Italy and everything. You can get a Tecomec that is exactly like a Oregon 511AX in every way except it is red with black knobs.
    Stinny likes this.
  19. jrcurto
    jrcurto
    SW Connecticut
    Just when I thought I was ahead getting familiar with one grinder. GHC. Now I have to hoard 3 grinders, right, left, rake...thanks.
  20. chris
    all pics 287.jpg all pics 286.jpg Unless you are doing a very high volume of chains 1 will be just fine. For me it is much faster not to have to reset the vise left right for each chain. This is slow time on chains only 33 of them this week from 18" to 48" bars 325, 375,404's. In total I have 5 grinders altogether. It was a real panic doing 8-10ft loops of Harvester types many years ago. In the lower corner you can just see a typical run of chains to be sharpened. Those look to be 20" Carlton A2 type
