Are the new Plasma lighters good for lighting wood pellets? - see vid
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Feb 1, 2018.
  1. don2222
    don2222
    Salem NH
    IHATEPROPANE likes this.
  2. imacman
    imacman
    Denver, NC
    $29 for a lighter? Me thinks.....NOT
    IHATEPROPANE, jtakeman and don2222 like this.
  3. Lousyweather
    Lousyweather
    How can it be safer? Put gel on the pellets, and you have to get your hand right in there, inches from the pellet/gel mix to ignite it? nah......good ole fashioned MAP gas!
  4. ChandlerR
    ChandlerR
    Seacoast NH
    I'll stick to my Mapp gas torch, thank you!
  5. Luneyburg
    Luneyburg
    Hills of Central Mass
    Neat Gizmo might be good for the outdoor use starting fires but have to concur with everyone else , I have a couple of Mapp torches down in the basement just in case one of the stoves needs some help getting started works like a charm.
  6. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    H e double toothpick I soak a handful of pellets in rubbing alcohol toss them into the pot one little match will do the job no need for even a Mapp torch to light it off.
  7. Lousyweather
    Lousyweather
    lol- yea, tried that......I went back to MAPP when my fire wooshed and burned some of the hairs on my hand off.....but if your careful, sure,this works well too.
  8. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Well you have to be careful no matter what fire starter you use.
  9. IHATEPROPANE
    IHATEPROPANE
    I know someone that used a tad of gasoline. Yada, yada,yada he needed a new convection fan and a new fire extinguisher.
    Luneyburg, imacman and jtakeman like this.
  10. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    How did he fair.
    imacman and IHATEPROPANE like this.
  11. heat seeker
    heat seeker
    Connecticut North Central
    You guys are missing the point. What if there’s a severe rainstorm inside the stove when you’re trying to light it?
  12. Lousyweather
    Lousyweather
    true, true.....and high winds?
  13. Lousyweather
    Lousyweather
    yes, certainly you do, but alcohol is pretty explosive itself.........dont worry, the hairs grew back......at least with the ole propylene, my hands aren't right in the mix, and there's no danger of residual liquid on my hands when i light the stove...
  14. ivanhoe
    ivanhoe
    Northern Ontario
    Can't light stupid either:picard:
    Luneyburg, imacman, ttdberg and 2 others like this.
  15. IHATEPROPANE
    IHATEPROPANE
    :heidi::heidi::heidi::heidi::heidi::heidi::heidi::heidi::heidi::heidi::heidi::heidi:
  16. jtakeman
    :eek:
    :doh:
  17. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    You didn't or did you jt?
    ivanhoe, IHATEPROPANE and jtakeman like this.
  18. jtakeman
    Nope! not me! ;)
    ivanhoe, IHATEPROPANE and imacman like this.
  19. badbob
    badbob
    LOL.I used gel for years,in the integra,then found out was faster with the self igniting torch,30 to 60 seconds,depending on how much pellets I threw in.Also,I have used cheap antiseptic hand wash,lots of alcohol,it works,good thing to take camping,that or pringles.
