Excessive draft - damper on rear exit install??
Discussion in 'Modern EPA Stoves and Fireplaces' started by Sutphenj14, Jan 22, 2018.
  1. Eric VW
    :zip:
    Must resist.....:rofl: :lol:
    yooperdave, papadave and brenndatomu like this.
  2. yooperdave
    [​IMG][​IMG]
    brenndatomu, papadave and Eric VW like this.
  3. Eric VW
    It too, has passed....
    yooperdave, brenndatomu and papadave like this.
  4. oldspark
    oldspark
    NW Iowa
    When ever I have too much draft do to a strong wind from the south my flue temps rise about as fast as the speedometer on my car and I have to watch the stove like a hawk, do you know if your stove is acting any thing like that?
    yooperdave likes this.
  5. Flamestead
    Flamestead
    Windsor County, VT
    Woodstock Soapstone added our damper while we were helping test their stoves, and it has been a great addition. Prior to it, we could bring the PH up to and level off at cruising temp, but no matter the temp we leveled off at we could not bring the temp back done until the load was past it’s peak. Now, with the flue damper, we have much more control, and we see no downside to having it.
    Sutphenj14 likes this.
  6. Sutphenj14
    Sutphenj14
    Grand Rapids
    I'll be putting in a damper next week and will report on the results. Thanks all for the help.
  7. jrcurto
    jrcurto
    SW Connecticut
    Jon, I will pay you for a forged extended handle just like yours. That is exactly what I need
  8. golf66
    golf66
    I had a Quad 4300 and controlling the burn was very difficult, especially on bitterly cold days when there was extra-strong chimney draft. I took the sides off the stove and found that even when the primary and secondary air intakes were "closed", there was still a huge gap. Something to do with EPA regs or whatnot. I cut some aluminum strips to completely cover the gaps and pop-riveted them in place. The stove was perfectly controllable after that. Perhaps the original poster has a similar issue on his stove, although I can't recommend that anyone modify their stove as I did.
  9. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I can make one. I'll pm you.
