  1. jtakeman
    Sounds nearly(but not quite) as bad as the bonehead who tore his whole stove apart cause he didn't turn the stat on............ :whistle:
    Double :doh: and now anytime theres an issue with the beast, The boss asks if I turn it on! :emb:
    :headbang:
    At least we admit our oops's Mr. Bear! :rolleyes: :p :picard:
  2. savemoney
    Does he know you are military? sounds like that 229 is the base price without a delivery charge.
  3. gbreda
    gbreda
    NH
    I did that with the sn*wblower last fall. Starting for the first time to test before it was neededc-made sure fuel valve was on but still would not start. Tore things apart when it still wouldnt go. In the end, at some point I turned the fuel valve off again :picard:
  4. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    I got 117 gallons should be it until late this year.
  5. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Well I haven't done anything like that with my stove it was perfectly capable of fsck'ng up by its lonesome until additional gasketing was added and the stove removed from start stop tstat usage.
  6. artc
    artc
    Rocky Hill, CT
    it's dual rear wheel, and the Trojan blade setup is like their road graders of the era - mid 1940's. the tractor weighs 5500 lbs without the aftermarket hardware, so probably 7500 lbs on the trailer.
    i will take my loader tractor out there, remove the dual wheels, and tow/push it on my flatbed trailer with the plow (8') stopping just behind the trailer tires. i'll enlist son David's help and use the pellet trailer for the loader tractor. at least, that's the current plan!
  7. gbreda
    gbreda
    NH
    I burned through more of the oil in the fall using only HHO at the time and then the cold snap used up some more. Now that I have switched back to 24/7 on the pellets oil use has dropped considerably. At these higher oil prices, its full on pellet time
    BTW, used Local Pride in Rochester and not Rymes as this is the co that I use to use. A little higher but local and can deliver next day, maybe 2 days if they are swamped. Smaller delivery area means better service. Credit Card in advance and done-no drivers lic or social # needed
  8. savemoney
    Wife has been having some issues that the doctor told her could be a gluten intolerance. he wants her to go gluten free for two weeks. I bought her some gluten free bread, $4.99 for a small loaf. The expiration date on the bread read, Aug 2018! Wonder if it is radiated.
    gbreda, IHATEPROPANE, bogieb and 5 others like this.
  9. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Had to put a new rim on one of these,blasted and painted,1946 john deere H 20180120_152425.jpg
  10. savemoney
    Those are nice looking wheels, fine work right there. So any new picks of what's been cook'in? I like those pictures too! :drool:
  11. ivanhoe
    ivanhoe
    Northern Ontario
    So do you now have John Deere yellow pellets?
  12. wildwest
  13. ivanhoe
    ivanhoe
    Northern Ontario
    My FIL would be proud of you only if it's the right color code for the year of that John Deere:whistle:
    Nice tire off paint job, kudos to you:thumbs:
  14. ttdberg
    ttdberg Pellet Pig
    CT
    Took advantage of the mild weather today and did a thorough cleaning of the P68 venting, as well as the stove itself. Going to be mild again tomorrow, well take it!
  15. ivanhoe
    ivanhoe
    Northern Ontario
    Just did the same on the Fahrenheit and switched to the old Fasco motor from the noisy Gleason/Avery one for the same reason as you, mild weather:yes:
    Having a tall can of Stella for all that hard work:coldone:
    Lacrete's in the hopper:thumbs:
  16. ttdberg
    ttdberg Pellet Pig
    CT
    :drunk:
    :dex:
  17. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    just cruise over to the smokehouse section....:banana:
  18. bogieb
    Apparently was a beautiful day here in NH. I don't know, I was in class all day. But, the good news is that now I am a certified bystander
    Accident Scene Management patch sm.jpg Accident Scene Management Certificate-blurred.jpg
    badbob, savemoney, Luneyburg and 8 others like this.
  19. CleanFire
    CleanFire
    "A Crash Course for the Motorcyclist" .. :picard: :rofl: :lol:
    Congrats B ! :thumbs:
    savemoney, gbreda, Luneyburg and 7 others like this.
  20. CleanFire
    CleanFire
    Not when I'm hungry, I won't! :D
