Few months of burning! How does this look?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Woodwhore, Jan 15, 2018.
  1. Woodwhore
    Woodwhore
    Mason NH
    5F7F44D3-C3AF-4545-BEF2-B6A42CB09318.jpeg 5F7F44D3-C3AF-4545-BEF2-B6A42CB09318.jpeg
  2. Well Seasoned
    Looks pretty good, mostly fly ash. It will be thicker toward the top. I good rule of thumb is to sweep it when you have a quarter inch of build-up. I just swept mine for the mid season cleaning.
  3. Woodwhore
    Woodwhore
    Mason NH
    Thanks , i swept it after but forgot to take a pic. Not much debris at all.
  4. Backwoods Savage
    More than I like to see with only a few months but not enough to make one pucker. Still not black gunk. Good that you cleaned it.
  5. Locust Post
    Not bad or what I would say dangerous but as Sav said, good that you cleaned it.
  6. Woodwhore
    Woodwhore
    Mason NH
    Well i say a few months but i cleaned it towards the end of last burn season so not so bad i guess. It really payd to have good seasoned wood. Iv been burning 3 year old mix of hardwoods. Mostly oak, iv got alot of maple to burn also. I made $1100 bucks off the giant pile of wood i showed you guys in my driveway. Well actually my wife did!
    Well Seasoned likes this.
  7. oldspark
    oldspark
    NW Iowa
    Do you monitor your flue temps?
    Woodwhore and Well Seasoned like this.
  8. Woodwhore
    Woodwhore
    Mason NH
    Iv got a gauge on the pipe about 12 inches up, i never let it go into overfire and try not to let it go into the lower temp that says creosote.
    Well Seasoned and oldspark like this.
  9. Woodwhore
    Woodwhore
    Mason NH
  10. oldspark
    oldspark
    NW Iowa
    I am surprised you have that much creosote in a few months time then, I dont get much at all in one winter but then I tend to run my flue a little hotter then a lot of people.
  11. Canadian border VT
    I'm seeing more fly ash than creosote some wood just makes more ash than others. Cherry for example.
  12. Woodwhore
    Woodwhore
    Mason NH
    It does get ran wide open with few logs at a time during the day too because the house gets too hot to pack it during the day for my wife and kids. She works from home so i just have her throw a few logs on at a time without messing with the flu. Im a hoarder what the hell im sittin on 6 to seven cords of two to three years old wood. So if its easier and more comfotable for her i dont mind burning a little extra. I do burn a good mix of wood though, ash, cherry,oak, maple, the birches a little elm. See what it looks like when i open it again i guess. I always have clean smoke outside too.
  13. oldspark
    oldspark
    NW Iowa
    Sounds like you are doing everything correctly, not sure why it would look like that in just a few months.
  14. Woodwhore
    Woodwhore
    Mason NH
    Thank you, how long would you wait to open it again?
  15. Woodwhore
    Woodwhore
    Mason NH
    When i swept it, it was dusty, i do it from the inside with the vacuum tube rt in the chimney opening. So i see and hear everything fall. No big shiny chips either. Cleanout box wasnt concerning either. Been cleaning it myself for 4 years and had my home for eight so im still learning and noticing new things. I do have to say iv learned alot just searching old threads. All you guys are great!!!!
  16. Woodwhore
    Woodwhore
    Mason NH
    That pic was old, iv done the floor, stained the beams and painted. Im getting rid of all the brown tile and doing something else under the stove, probably slate??? Its progess all the beams were brown, which was nice but the wife wanted ebony, i think she did great job with the colors. Yup still some christmas deco to take down. 253075F5-38C8-4853-9A73-17E79DE566F5.jpeg
  17. oldspark
    oldspark
    NW Iowa
    You have a nice house there.
    I would do it in a few months again so you have an idea of what it is doing, pick a nice day when the temps are in the 20's or 30's at least.
    FatBoy85, Woodwhore and Well Seasoned like this.
  18. Well Seasoned
    I forgot to ask earlier, is that an insulated liner?
    Woodwhore likes this.
  19. Woodwhore
    Woodwhore
    Mason NH
    Im not sure, how can i tell and does it matter if it is or isnt?
  20. Well Seasoned
    Usually the liner has a thermal blanket wrapped around them, sometimes the chimney area is filled with vermiculite too. A chimney is cold, having an uninsulated liner would create alot of creosote/ build-up, especially with a chimney that is outside the house. It would be kinda hard to see if it's insulated or not. Taking the pipe off the snout at the thimble area and a mirror/flashlight could make it possible or from up top on the roof.
    mirnldi and Scotty Overkill like this.
