Charcoal starting chimney suggestions
Discussion in 'The Smokehouse' started by J. Dirt, Jan 6, 2018.
  1. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    Cast iron skillet sitting on top of the chimney is quick, easy, and provides a great hot sear if your in a hurry.
    JWinIndiana and J. Dirt like this.
  2. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    :headbang: When I was doing a lot of dutch oven cooking I never ever thought of this! Good hint!!:yes:
    Mitch Newton and J. Dirt like this.
  3. J. Dirt
    J. Dirt
    But it says on the package not to do that! :rofl: :lol: :pain::rofl: :lol: Warnings are just suggestions anyhow :D:flipeggs:
    Mitch Newton likes this.
  4. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    On mine the warning label was glued to the outside of the chimney. Figured after the first burn there weren't any rules as there wasn't any label anymore!:rofl: :lol:
  5. J. Dirt
    J. Dirt
    Some guy at the factory is laughing right now about gluing that label on.
  6. Eric VW
    I use a store bought piece, it’s old and rusted now -not a Weber- but if I’m doing a big smoke, I’ll start in the chimney, and then dump into one of these, which I’ll fill 1/3 with lump charcoal-
    I time it so that when both briquettes and the lump are greyed over, it’s ready to go in the side box.
    J. Dirt likes this.
  7. J. Dirt
    J. Dirt
    Busted it out tonight! It was around 50 today and I couldn’t resist grilling so of course I had to try the chimney!
    2 small sheets of newspapers touched her off
    4:57pm D8A2985A-51D4-4C1F-AC7F-C892A7D824CF.jpeg
    5:07pm DD40BE7E-8E29-4723-BA0C-4F9A8A70EBB6.jpeg
    5:11pm 417F6CAB-A7D9-4333-A48E-BFE2DDBE78EB.jpeg
    5:19pm 895E0D80-8C6A-4515-9210-D77481E6CCC1.jpeg
    Yeah this thing is sweet!!
  8. Matt Fine
    Matt Fine
    New York
    Next time skip the news paper (they still make those? :D) and set it on your propane burner like from a turkey fryer or brewing setup. The times you posted will come down substantially.
    For a fast sear, get a $10 replacement grill grate for a small Weber and set it on top. Better air flow than using a pan.
    Eric VW and J. Dirt like this.
  9. J. Dirt
    J. Dirt
    I’ll have to try the propane shot! :thumbs: As far as the pan that was a piece of sheet metal I hacked with my sawzall to fit the grill for my Dutch Oven otherwise the legs fall in between the grates.
    Soon to be thread on my welding project for a D O cooking table :D
    Eric VW and Matt Fine like this.
  10. Matt Fine
    Matt Fine
    New York
    I was referring to the suggestion of putting a cast iron pan on top of the chimney to sear. Fill it up and get it going like your last pre-dump pic, set a cheap grate on top and you have the perfect searing setup. You can sear a steak in about 30 seconds per side.
  11. J. Dirt
    J. Dirt
    Got ya! I’m a bit slow sometimes:loco: :crazy::picard:
    That sounds like a plan! I’ll have to see what I’ve got kicking around here might just have one:flipeggs:
    Eric VW likes this.
  12. Matt Fine
    Matt Fine
    New York
    You can use anything that won’t melt or let your food fall through. That said, the best results actually come from a cheap thin grate that doesn’t block the flame and intense IR. Instead of grill marks, for best flavor, you want a dark even sear all over, especially on the big spaces between the grates. A cast iron pan or griddle will also give a nice even sear but it blocks too much airflow on that style chimney. If you want to go that route, I am guessing you have the fab skills to come up with something to sit on top and let the flames spill out and around the pan or griddle.
    TurboDiesel, J. Dirt and Eric VW like this.
  13. Eric VW
    When I’m in a hurry and don’t have any of those old fashioned newspapers Matt Fine mentioned, I’ll drop about 5-6 “instant” light briquettes in first, then load regular briquettes and fire them with the MAPP torch.... yields ready coals in 10 minutes or so....
    J. Dirt likes this.
  14. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    I have been guilty of buying gizmos, that is what I thought this was years back when I saw one. If you have ever tried just starting charcoal, then starting charcoal in one of these, it is amazing the difference! Just built and gave my son in law a D O table for Christmas (still in the bed of my truck. He had been lusting after mine, so built him his own.
    J. Dirt likes this.
  15. J. Dirt
    J. Dirt
    :ithappened:Well?......:D
  16. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    Looked through my phone, have a couple shots of it in its build. It was originally a U shaped piece of metal, had a student cut it off and reweld it as a Z. You can see it in the pictures. Legs were added with braces for a shelf if he wants it.
    J. Dirt and SKEETER McCLUSKEY like this.
  17. J. Dirt
    J. Dirt
    How thick is that steel? I’ve been trying to decide what I wanted to use. I want it to be somewhat portable but don’t want it to be flimsy and warp from heat. Ps is that a 154 cub in the background?
  18. swags
    swags Moderator
    Gonna melt that little grill
    J. Dirt likes this.
  19. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    I think it is 16 gauge, might be 18 gauge. Two people can move it easily. Why yes that is a 154 with the wide tires.
    J. Dirt likes this.
  20. J. Dirt
    J. Dirt
    :thumbs::D
