Snatch block for synthetic rope
Discussion in 'Chainsaws and Power Equipment' started by Screwloose, Jan 6, 2018.
  1. Screwloose
    Hello. I'm trying to figure out what is the best snatch block to get. I have never used synthetic rope before and don't want to mess it up. This is what I will use it with. 3/8" dia. Thanks for your help. IMG_20160820_190232252.jpg
    J. Dirt, Hammy and tamarack like this.
  2. fuelrod
    fuelrod
    Western Maine
    I would think that just as with wire rope, the larger diameter sheave would be better for the line and any snatch block with the appropriate rating would do. I could see where the use of a snatch block may be less harmful to synthetic rope than to cable bending around a fairly small pulley while under load. This is just a guess, but I'd love to try some. The cost is always a consideration along with some abrasion situations I can get into winching logs in & through the woods. The light weight and good "spooling" manners sound real nice to me. HF has a pretty "normal" looking snatch block for $27. That's pretty cheap and the only diff. between it and a more expensive one I have is the acural sheave is aluminum (no biggie with syn. rope) and a hollow "axle", more like a 2" pipe vs a 1" solid steel on the expensive one.
    Hammy, Dancan and Screwloose like this.
  3. fuelrod
    fuelrod
    Western Maine
    Screwloose, have you worked your winch yet? I'd like to have a self contained winch like that. :thumbs:
    Any action pics?
    Hammy and Screwloose like this.
  4. Screwloose
    I have Mckissick ones for my wire rope. But i was concerned because they ooze grease from the gap between the sheave and side plates. I was looking for something a little more robust than the pressed out hf ones.
    Hammy and fuelrod like this.
  5. Screwloose
    No but the property I cut on is for sale so I have to get moving or risk losing it. I'm sure anxious to try it especially since my health is doing better. I sure miss being out there !!!!
    fuelrod likes this.
  6. fuelrod
    fuelrod
    Western Maine
    Let it warm up some, then got out there and take us some pics:D just take it easy.
    Screwloose likes this.
  7. amateur cutter
    How much you want to build me one of those? Yes I am serious.
  8. Flamestead
    Flamestead
    Windsor County, VT
    Liking the LocknLube in the photo - I've been using one for quite a few years now - the guy that got the distribution rights for it was a co-founder of the logging company my wife works for, so she got a pretty good deal on them.
    Back on topic, I haven't tried the synthetic rope yet, but my cable has some jaggers and they are taking a toll on my chaps and gloves, and I like the idea of better spooling a lot. I wonder how well the rope will stay on the snatch block, before the pulling starts. Seems like the weight of the cable helps keep some tension to hold itself tight to the pulley.
    fuelrod likes this.
  9. Screwloose
    To build what ?
  10. amateur cutter
    That self contained winch assy. Or did you buy that?
  11. fuelrod
    fuelrod
    Western Maine
    Very true, I also remember why I cant use it.....the sliders. I run 4 sliders and remember reading about the one shortcoming was abrasion. My winch cable is still in nearly new cond except for the 12' of so I had to cut off the end. Next cable will be the swaged type. A friend runs it on his winch and it's a llittle stiffer but resists crushing on the winch drum.
    Hammy, Flamestead and Screwloose like this.
  12. Screwloose
    I found mine on Craigslist, but it came from Winches Plus.
    Dancan and amateur cutter like this.
  13. Screwloose
    that is what I have on "Wendy". I've never used sliders before all my chockers are the "cat" style with the eye. I just clip a few in the hook. So as long as I can avoid dragging it across stuff I think I will be ok.
    fuelrod and Flamestead like this.
  14. Flamestead
    Flamestead
    Windsor County, VT
    Good to know about the sliders, as that is how I’m set up, too. A friend had told me me preferred the swagged cable, but I’ve never had a chance to work with it. I suspect this cable has quite a few more years of life left in it.
    Screwloose , your portable winch reminded me of this winch. It is used to help heavy machines maneuver steep slopes. Please keep us updated on how you like your setup over time.
  15. Screwloose
  16. Flamestead
    Flamestead
    Windsor County, VT
    Nice - I like both those winches. It is fun to study how things have been built to be compact yet functional.
    It looks like the drum on your newer winch is relatively small in comparison to snatch blocks I’ve used, so I think the snatch block won’t be a big issue. If you use a self-releasing style you might need to pay particular attention to the style of the edge it releases off, and make sure you don’t get a rough edge over time.
    I’ll post a picture of the one I use with cable later today.
  17. amateur cutter
    Thank you, I'll be looking that up in minute!
  18. Barcroftb
    Barcroftb
    The Mitten
    amateur cutter likes this.
  19. Flamestead
    Flamestead
    Windsor County, VT
    This one came to me second or third hand. I would think a thicker, rolled edge would be easier on your rope if you were to be using a self-releasing one.
