You heat pump guys will appreciate this one lol
Discussion in 'The Wood Pile' started by CHeath, Jan 6, 2018.
  1. CHeath
    CHeath
    NWNC Mountains
    Ok so most of you have oil as a backup because you are way north from me and I get it, a Heat pump just won’t cut it. Well, here on the ol’ south, USUALLY, heats pumps fair pretty well. This is what you get when you are out of town most of the week and are not able to burn and it’s single digits with wind. Glad I’m home.
    mat60, MO. Wood, savemoney and 10 others like this.
  2. fuelrod
    fuelrod
    Western Maine
    Last summer we installed a 2 head mini split ductless heat pump primarily for A/C (yes, a/c in Maine) and the "shoulder" heating seasons, before we fire up the big guns. They have been off for 6 weeks or so as we're now 100% wood, but just for the heck of it just the other day I turned one of them on @ about 8* outside. Much to my surprise it was blowing hot air. It does not have the backup electric resistance "emergency" heat, 100% heat pump. I was impressed.
    mat60, MO. Wood, savemoney and 11 others like this.
  3. dingbat
    dingbat
    Western Northern Cackalaky
    Those temps look awfully familiar. I've been home nights and working the stove hard. Managed to keep the heat pump off 'til the early morning hours most nights. Unfortunately need to keep some space heaters running in the cold, dark corners of the house and basement though.
    mat60, MO. Wood, savemoney and 7 others like this.
  4. TurboDiesel
    Many people think heat pumps can't make heat below 32 degrees, and in the past that was true, but today's heat pumps are extremely efficient! They have come a long way in a short amount of time.
    One of the biggest problems with heat pumps is the owner. They think they can save money by turning the unit off and then complain that the unit doesn't make enough heat. These units need to run a longer time, but they are made to run longer and use less electricity.
    mat60, MO. Wood, savemoney and 6 others like this.
  5. fuelrod
    fuelrod
    Western Maine
    The literature boasted that is still had close to 100% (if not 100%) efficiency down to 5*.
  6. TurboDiesel
    That is incredible!:yes:
    mat60, MO. Wood, savemoney and 5 others like this.
  7. SteveM
    SteveM
    Northern Maine
    ...and Dennis Lee was imprisoned for years for selling heat pumps 25-30 years ago, mostly because he forgot to fill out some form that NO ONE HAD EVER HEARD OF and that no one has ever been prosecuted for, before, or since.
    mat60, MO. Wood, savemoney and 4 others like this.
  8. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Can one of you guys share some literature on the setups you have, likes/dislikes?
  9. fuelrod
    fuelrod
    Western Maine
    I'm not a HVAC guy, but like any other hvac "system" it needs to be properly sized for YOUR home including insulation, windows and quantity, etc. I have been told that it is not quite as critical as the older set ups because the motor & compressor operate at a variable speed with a "soft start" that provides some of the efficiency. The older "conventional" motor/compressor's were either on or off. But again someone who actually knows (yooperdave iirc) might jump in here.
    Just google "mini split'' or ''ductless mini split heat pumps''. Mitsubishi, LG, Fujitsu are some of the players. We got a $750 rebate check from the state from an efficiency program fwiw.
    We're only into this about 4 months, but so far it's all thumbs up!
  10. CHeath
    CHeath
    NWNC Mountains
    I have a new trane XR15 that was installed and sized for my home by my best friend who is a trane rep. New unit inside and out. It really runs well and keeps the house warm but this cold snap is probably the worst I’ve ever had in my adults years and some may chuckle but it just doesn’t get that cold here. It was 6 this morning. When those temps get that low, my unit will run 18/24 hours and about 5 of those hours will be emergency heat. That’s just dollars going out the window to me. Especially when I can make it 80 in here for a fraction of the cost and have fun doing it lol.
    mat60, MO. Wood, bear 1998 and 3 others like this.
  11. termitebuffet
    termitebuffet
    That's a nice app ??? More info ?
    Sent from my SM-N910V using Tapatalk
    mat60, MO. Wood, bear 1998 and 2 others like this.
  12. firefighter938
    firefighter938
    Central Indiana
    How did you obtain that information?
  13. TurboDiesel
    Dennis Lee plaid guilty and was imprisoned for selling "Marketing Kits" to potential dealers/investors...otherwise known as fraud....not heat pumps
    mat60, brenndatomu, MO. Wood and 4 others like this.
  14. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Thanks. I am looking for a backup when I am traveling. I can do the work, just want a solid system.
  15. termitebuffet
    termitebuffet
    Is that screenshot data tstat ? Or other software monitoring system ?
    mat60, MO. Wood and bear 1998 like this.
  16. SteveM
    SteveM
    Northern Maine
    Uh huh. He had heat pump technology all worked out twenty years before all these companies stole his ideas, and he was railroaded because somebody didn't like their power sales being impacted so negatively. The oil and utility people have done far worse to others over the years.
  17. SteveM
    SteveM
    Northern Maine
    That having been said, yes, he over-promised at times, and overstated COPs, but that's minor compared to what his work has done for humanity, and the time he spent in San Luis Obispo is a stain on America.
    mat60, MO. Wood, savemoney and 2 others like this.
  18. MightyWhitey
    MightyWhitey
    I always thought that "heat pump" was a term that described a household POS utility that keeps you warm in Summer and cool in Winter.
    mat60, MO. Wood, dingbat and 4 others like this.
  19. fuelrod
    fuelrod
    Western Maine
    mat60, brenndatomu, MO. Wood and 6 others like this.
  20. dotman17
    dotman17
    Snohomish, Washington
    You can get quality heat pumps for $16k or you can get a quality pellet stove for $4K. In 3 years, my pellet stove will have paid for itself in savings. I'm guessing 10 years to pay for the pump. Even if the heat pump saves more money at a better rate, I'm still coming out ahead in the first 13-15 years or so because of the savings I'm accruing for the 7 years difference. Based on that loose logic and data, the way I see it, heat pump owners don't start pulling ahead of me until nearly 15 years down the road. Yes, this assumes of course that biomass fuel remains constant over those years -- something we all agree isn't happening. But it does illustrate that a pellet stove owner is likely to be ahead of the game than you heat pump guys for some time.
