Nor’Easter 10-12” NE Coast today - Do you have any ailing parts and a spare?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Jan 4, 2018.
  1. don2222
    don2222
    Salem NH
    Hello
    The storm is here and extreme cold after it!
    My Shop stove’s Distribution Blower is louder when turned up all the way to high. A new one maybe a little quieter. No need to replace it right away. Just good to have a spare in case.
    Do you have any noisy bearings or squeaky augers or auger motors?
  2. bearverine
    bearverine
    Winchester, Indiana
    I certainly do have a loud auger. Girlfriend thinks the stove is haunted.
  3. don2222
    don2222
    Salem NH
    First thing I would do is pull the auger and buff it out with a wire wheel on a drill driver.
    CleanFire and SKEETER McCLUSKEY like this.
  4. don2222
    don2222
    Salem NH
    Hello
    Wow!
    Now they are saying it will be -19
    Degs Saturday night down from -15 Degs in the prior screen shot!!!
    Will your basement pipes be safe from freezing?
    CleanFire likes this.
  5. peterfield
    peterfield
    I have to give the 52i a rest and use the oil burner so the pipes in a couple of spots don't freeze. I have experience with this - twice!!
    CleanFire and ttdberg like this.
  6. ttdberg
    ttdberg Pellet Pig
    CT
    X2
  7. ChandlerR
    ChandlerR
    Seacoast NH
    I know I'm going to jinx myself, I just know it....but so far everything has been running like it should. The only thing I have done is increase the temp settings to #4 out of 5. I have never run this stove on high since I owned it. I may try it tomorrow.
    CleanFire and don2222 like this.
  8. CleanFire
    CleanFire
    We have the FHA oil furnace thermostat turned up to 70F, so it will cycle every 45 min/hour to keep the downstairs heated to 38-40F. Still running 1.8 lb/hr on the little stove here, everyone's warm & comfy.
    Wind is steady 15-20 MPH, had to dial down the Combustion blower RPM 5%: was loosing 25-30F of heat output from the Heat Exchange tubes (173F vs. 205F), as measured earlier today.
    Have a safe evening, stay warm all. :yes:
