Laminate Flooring
Discussion in 'The DIY Room' started by eatonpcat, Dec 26, 2017.
  1. huskihl
    huskihl
    savemoney, eatonpcat and yooperdave like this.
  2. Eric VW
    Well, I’ve seen you NOT cut, split, & stack firewood before....but you laid your (plastic) wood pretty darn well....:thumbs:
    :handshake:
    Nice work:yes:
    milleo, savemoney, Jack Straw and 2 others like this.
  3. bogieb
    lOOKS REALLY NICE!
  4. Woodwidow
    That looks really nice.
    savemoney, Eric VW, papadave and 4 others like this.
  5. eatonpcat
    Thanks all.
    savemoney, Eric VW, papadave and 2 others like this.
  6. ironpony
    ironpony
    Mid Ohio
    Why did you cut the casing legs so short? :emb:
    Looks very good.
    When you nail the base back on make sure to hit the studs, but you knew that already.
  7. ironpony
    ironpony
    Mid Ohio
    Also a good time to paint won't have to cut in all the base trim......
  8. eatonpcat
    The casing trim is a separate block...the header trim is a bigger PITA.
    milleo, savemoney, bogieb and 3 others like this.
  9. eatonpcat
    So to put the oak baseboard up, will a 16 GA nailer do the trick?
    Eric VW and bogieb like this.
  10. Eric VW
    Yep... did you remove old nails from the trim yet?
  11. ironpony
    ironpony
    Mid Ohio
    yes and with that trim I would use 2 1/2 inch nails. When you pull the nails out of the "old" trim use linesman pliers and pull them from the back, pulling the nail thru the trim, it won't chip the face. They should pull thru fairly easy, not much of a head on gun nails. I use the cutter part, pinch the nail and twist the pliers against the trim, rolling the nail out. It will take a few tries to get the feel so you do not cut the nail. Or you could use flush cut dykes and cut them off you are going to have to fill the holes anyway.
  12. eatonpcat
    savemoney likes this.
  13. Eric VW
    I use these, and pull thru like you're saying to do IP...
    The curved head provides a smooth levering action. Just apply enough pressure to "bite" the nail shank, but too much will cut the nail. I love my nippers!
  14. papadave
    Channel Locks will work too, but they sometimes slip.
    I'll sometimes go sideways with 'em on the stubborn nails. Not so gooder for hangnails though.:whistle:
    savemoney, eatonpcat and Eric VW like this.
  15. eatonpcat
    Those will work great on everything but the corner posts, I think I will have to cut those nails off with the Dremel. These nails are almost impossible to extract.
    savemoney, yooperdave and Eric VW like this.
  16. Eric VW
    These are the brand of flush cutting snips I used for years in both trim work and transformer assembly...used them the other day on some nail removal.
    Xuron 2175A - Maxi-Shear Full Flush Cutter - Full Flush - 5.82"
    savemoney, papadave and yooperdave like this.
  17. eatonpcat
    savemoney, Eric VW and yooperdave like this.
  18. Eric VW
    Welcome....:handshake:
    savemoney, yooperdave and eatonpcat like this.
  19. wildwest
  20. Eric VW
    Order a pair yet..... of Xuron’s?
    Had to specify that last bit, as I’m sure some may have thought I was implying you needed to bolster up.:whistle:
    bogieb, papadave, savemoney and 2 others like this.
