New Stihl FS94R,Old School 2stroke engine
Discussion in 'Chainsaws and Power Equipment' started by rookie1, Mar 14, 2014.
  1. rookie1
    rookie1
  2. Fanatical1
    Fanatical1
    So were back to the good old two stroke again?! I thought the 4mix was the way to meet EPA regulations?
  3. rookie1
    rookie1
    Dealer says its strato charged and burns cleaner than the 4mix. :eek:
    Pallet Pete likes this.
  4. MasterMech
    It's one way to do it. Stratocharged two-strokes are another. The four-mix has met with some resistance among the pro crowd looking for a lightweight pro-trimmer. I like the FS100RX just fine but have to admit Stihl didn't have anything on RedMax or Shindawa in that department.
  5. bocefus78
    bocefus78
    Yup. I have 2 of the 4 mix fs90. They run fine but compared to echo or shindy they feel like concrete blocks. 24 cc on this new one. 28 on the fs90. Does a strato make that much difference?
  6. MasterMech
    Strato doesn't really add power all by itself, but it will clean up a 2-stroke enough that catalytic mufflers and mini 4-strokes are not necessary. I like 'em just fine on my saws and a lightweight trimmer. The 4-Mix is amazing with big loads on it however. I have an FS110R and it is a powerhouse for it's size/weight. Put a powersweep attachment on one and you'll understand. My BR600 is a beast as well.
  7. rookie1
    rookie1
    I think the advantage of the 2 stroke is simplicity. Not that adjusting the valves every year is a big deal, its just less moving parts. Emissions aside. :)
  8. MasterMech
    Simple he says...... :rofl: :lol:
    Simple in terms of moving parts, indeed. But lemme tell ya, trying to understand how these engines, especially newer ones, work beyond the basics of suck squish bang and blow, is enough to make my brain hurt.
    Guys that modify them for even more usable power without severely compromising reliability have my utmost respect. Because when the laws of fluid dynamics are applied to these little bastards, they are anything but simple! Just try calculating an accurate compression ratio for a two-stroke. ;)
  9. rookie1
    rookie1
    Simple in the fact that only 3 parts move,crank, rod piston. 4mix has those 3 plus cam,2 pushrods, 2 rocker arms and 2 valves. My count is 3 to 12. :)
